Old 09-18-2018, 02:11 PM   #1
Kenney Kelley
Liked 72 Times in 36 Posts
Default Re: Electrolysis in aluminum radiator - Help
If you remove the battery's from the car. Do you have voltage? If you don't you might have a bad battery. Also is the radiator got rubber mounts on top and bottom. I don't no if you have tried these things or not. Might help and might not
Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 09-18-2018, 02:59 PM   #2
FED 387
Liked 334 Times in 181 Posts
Ground the radiator to the frame/body!!!!!
Old 09-18-2018, 03:04 PM   #3
6130
Liked 117 Times in 50 Posts
What's the pH of the coolant?
Two dissimilar metals in the presence of an electrolyte = battery.
Old 09-18-2018, 03:16 PM   #4
FED 387
TRue---could be lots of minerals in your water causing problems too---
Old 09-18-2018, 04:22 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
This type of problem is one of the reasons GM developed DexCool .
Old 09-18-2018, 04:40 PM   #6
David Lee
Liked 346 Times in 126 Posts
there could also be bad grounds in other circuits. Measure the voltage in the radiator and turn on every circuit one at a time. if you get a voltage jump. if you get a voltage jump. You found your bad ground.
Old 09-18-2018, 05:05 PM   #7
1legjerry
Liked 72 Times in 15 Posts
Might also try using water only, Also Ground each head to the chassis and ground the radiator to the chassis.
Another product that we have used is Bar's leak coolant additive.
https://barsleaks.com/product/coolin...ith-anti-rust/
1legjerry is offline   Reply With Quote
