Old 09-09-2018, 08:32 PM   #61
Dan Lattimore
Liked 154 Times in 37 Posts
Default Re: What factors Determine Tow Rating
Dan, from a local trailer dealer. Back in about 2008. I told the guy at a trailer & trailer parts dealer here what I wanted to do. I had trouble blowing out the 15" "trailer rated" tires that. And on it. Had 5 lug wheels, like a car. Found they were speed rated at 65 MPH. The speed limits on the many toll roads here is 75 MPH. I had a diesel motorhome until recently that I just set the cruise control, it ran the speed limits like the trailer was not back there. Ignorant me, I was not aware of the tire speed ratings. Blew out a few. SMH
The trailer parts guy told me I needed to put 16" wheels on it, to get the load ratings & speed ratings I need to run the speed limits. Same 8 lug wheels & tires as my 2500 Suburban. Tows so much better. The original trailer tires & our 1/2 ton Tahoe towed it, but not nearly as stable as the 3/4 ton Suburban & better tires.
Had to buy the whole assembly for each trailer wheel. Four bolts holds each to the end of the trailer axle. You will see the difference first time you tow it. I thought the 1/2 Ton Tahoe and 15" trailer tires were fine, until the first trip with the new stuff. Safer & more comfortable on windy days, also on 2 lane roads with 18 wheelers. I have the same 16" Michelins on the trailer as the Suburban. They use 65 psi. Same 8 lug wheels.
Hey Ed ---- Thanks for the great info, exactly what I've been wanting to do. --- Danny
66W30POST
Dan Lattimore is offline   Reply With Quote
Old 09-10-2018, 11:24 AM   #62
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by GTX JOHN View Post
I agree with the above two posts!
However, many trailer will not accept the 16 inch
wheel/tires due to the fender not clearing.
That is my situation.
There was a good conversation on Trailer Tires earlier this year.
I got new 6 ply now know 8 and 10 ply are available for the 15 inch wheel.
Also learned the manufacture says you can run 70lbs on a 65lb rated tire.
On trucks Dodge, GM and Ford have an impressive new offerings and choices.
Old 09-21-2018, 05:39 AM   #63
6130
Liked 117 Times in 50 Posts
Dan, you came here and asked a question. A lot of people, with a lot of experience in this area, gave you your answer:
Originally Posted by Rusty Davenport View Post
All of these performance ratings are great but if you are planning on leaving town......GET THE VEHICLE WITH THE BEST BRAKES AND THE MOST WHEELS ON THE GROUND.....THE PERFORMANCE IS NOTHING WHEN YOU ARE HAULING *** AND THE BRAKE LIGHTS START TO COME ON IN FRONT OF YOU !!!!!!!!!!!
Originally Posted by 6130 View Post
Are you talking about the Silverado 1500?
With all due respects, I would not tow three tons of stuff behind a half-ton pickup on a public road shared with other motorists.
For starters, the 2019 Silverado 1500 comes on P-metric (passenger car) tires. Light-duty truck (load range "C") tires are an option. No load range "E" or even "D" truck tires are available on the Silverado 1500.
Half-ton trucks do not come with full-floating rear axles, so if you break a rear axle outboard of whatever is retaining it, you lose a rear wheel and half of your braking system.
I don't know what rear end GM is using for the particular Silverado 1500 variant that you're considering, but historically, GM's half-ton pickups have used C-clips at the inboard ends for axle retention, which means that if you lose a C-clip or snap an axle anywhere outboard of the C-clip, you lose a rear wheel and half of your braking system.
Half-ton pickups also have much smaller brakes, smaller wheel bearings, and so on, which makes them less safe when towing.
Modern light-duty trucks have a lot more horsepower than older light-duty trucks did, the transmissions are certainly getting better, and the manufacturer's tow ratings have increased because of this, but I wouldn't tow three tons of stuff with anything less than the sturdiest 3/4-ton pickup, and even that would be a big compromise.
The smart choice would be a one-ton with proper load range "E" tires, dual rear wheels, and a full-floating rear axle. Keep in mind that even a one-ton 3500 is still technically a light-duty truck.
You don't need to pay for a fancy diesel engine to tow a car trailer. Escalating wants and desires of consumers fuel the current horsepower and torque race in light-duty trucks, but the truth is, modern pickups are not lacking for horsepower, no matter which engine you choose. People have successfully and safely towed massive amounts of stuff with no more than about 200 horsepower, forever. Diesel fuel typically costs more than regular gasoline in the U.S., which makes it nearly impossible to recover the additional cost of a diesel engine option based upon any actual fuel savings that may or may not occur.
If you skip the foofy stuff, you can get a one-ton dually for no more money than a typical loaded half-ton. GM's "W/T" (Work Truck) comes to mind- they may come with rubber mats and vinyl seats, but they are far from stripped. GM's one-ton dually W/T comes with big 4-wheel power disc brakes, ABS, power steering, air-conditioning, power windows, tilt steering column, cruise control, power door locks, a 6-speaker audio system with blue tooth, a 7" touch screen, a rear-vision camera, an Eaton locking rear diff, a 2.5" hitch platform, trailer wiring, integrated trailer controller, heavy-duty 6-speed automatic transmission, heavy-duty engine oil cooler, 150-amp alternator, heavy-duty transmission cooler, 4.10 rear end gearing, and a standard 360-horsepower Vortec 6.0 V8 gas engine. Looks like they start at $40,595, and you'd probably be able to negotiate a price less than that.
Operating well within the rated towing capacity of a vehicle (like for example towing a 6,000-pound trailer behind a one-ton dually that has a 13,800-pound rated towing capacity) would be much safer than towing something that is at or near the maximum rated towing capacity of a vehicle (like for example towing a 6,000-pound trailer behind a vehicle with a 7,400-pound rated towing capacity).
It's not like you're 100% safe towing 7,399 pounds and the truck spontaneously blows up at 7,401 pounds- the laws of statistical probability are at work here. If you're maxxed out on your towing capacity, then it stands to reason that you would be expected to be the first one to have problems. Heck, I've seen plenty of tire, brake, wheel bearing, and rear drive axle failures in half-ton trucks that have never carried or towed a load.
Originally Posted by Tar Heel View Post
I don't have a dog in this fight but I know in the last 2 years we've towed 7K lbs. (24' enclosed trailer and car) with a very well equipped late-model GM 1/2 ton truck. We then sold that truck and bought a 3500HD DRW 4WD Duramax and towing the same set-up was night and day difference. I'm not even talking about the power either. The 1/2 was a constant white knuckle event with sway even with good weight distribution bars and a sway control kit. All of that disappeared with the one ton. Tow with a DRW truck one time and see if you ever go back.
Half-ton trucks may be better than they used to be in some ways, but half-ton trucks have never come with full-floating rear axles or load range "E" tires, and those things were standard on 3/4-ton trucks for many, many years.
Conversely, 3/4-ton trucks have never come on P-metric (passenger car) tires, and 3/4 ton trucks have never had their rear axles held in by something as flimsy as C-clips.
Just take a stroll through the pits at a local points meet. That will answer all your questions regarding 1/2 ton pickups. Do you want to save money,.....or save your life....??
Originally Posted by james schaechter View Post
The only person that will really push you to a 1/2 ton is a salesman with a lot full of half tons for sale! I agree, the new half tons are much better than they used to be. They might just let you drive over your head. 3/4HD and one tons are much more stable, safer braking, and will be more reliable as they age. A half ton that barely makes the grade is stressed a lot more for my comfort level.
X2, also in one of the related threads someone mentioned the financial benefits of possibly just renting a truck for towing a trailer a few times a year. Not wanting to use my Motorhome for a quick 5,000 mile trip to pick up my new race car I rented a 3/4 Ford from Enterprise Rent a Truck and with the 6.2 gas motor it performed flawlessly for far less $ per mile than I could have done otherwise, new trucks are so pricey renting may make sense for you as well.
Originally Posted by 1320racer View Post
this^^^ and this vvvv
Exactly.
...and other people's lives too- there are other innocent families out there on the roads, that may not be as keen on risk-taking.
Yup. I'm born and raised in the car business (although I worked in the back end, not the front end), and I can't even begin to tell you how many times I have seen some coke-head car salesman blowing smoke up somebody's butt regarding this subject.
They're afraid that if they tell the customer that he would be safer towing a 3/4 ton, a one-ton, or a one-ton dually, that he'll lose his sales commission to some other coke-head car salesman down the street, when the other guy offers to sell him a half-ton pickup and a 5th wheel hitch to go with it.
Originally Posted by nhramnl View Post
Jim is right on the money. I would venture to guess that there isn't, and won't be, anybody who says they've used both 1/2 and 3/4 tons pickups and would be completely satisfied with a 1/2 ton. I've used 2500 HD Chevys for decades and have never, in any situation, felt I had "too much truck" for the task. I think the real truth with people who say a 1/2 ton works fine as a trailer puller is that they either don't have, or don't want to spend, the extra money.
Originally Posted by Barry Polley View Post
Oh for sure. But, the new 2500/3500HD plus trucks also have bigger brake packages. I put safety first. Not $. You are asking a light duty truck to do the job of a Heavier duty truck. I like most guys on here have towed with lighter trucks. I like piece of mind. IMHO...
James, it likely won't be what the knowledgeable, experienced racers he asked have recommend. He always spends a couple of days telling people what the correct answer is, when he asks for advice.
Not likely many that have towed with both a 1/2 ton & 3/4 ton would prefer the 1/2 ton. There is much more to it than brakes. Go to an NHRA race (not talking local bracket races) and see how many are towing with a 1/2 ton. Much more to it than brakes, people that have towed with both know that. Maybe the wind never blows where Dan lives & races. He is also trying to race a very heavy car.
Originally Posted by Dave Gantz View Post
Dan, don't take offense, your questions always seem to be looking for the lest expensive solution. As Ed said, then you try to convince all of your advisors that they are wrong.
It's easy for me to spend someone else's money, but the obvious solution is to get something that will do the job as safely as possible, for your sake and everyone else's around you.
I drove 1.3 million safe miles in a tractor trailer. It was always more than capable of doing the job, in all kinds of conditions. (A very important aspect.) I don't know if I could say the same if I drove 1.3 million miles in a borderline safely loaded 1/2 ton truck with trailer.
Originally Posted by Ronnie Hamlin View Post
When (not if) you get into an emergency or panic situation, you will be thankful if you have more vehicle than you need for what you're pulling.
A lot of us have been there.
Originally Posted by Shaun Quill View Post
I believe in overkill when it comes to towing. Much better safe than sorry. I’ve been there and I’ll never tow with any less than a dually. Dual wheels make it so nice going down the highway and if you ever come up on a hairy situation you’ll be glad you had those big brakes. Station wagons may go up and down the highway just fine, but if you ever need to avoid a situation or stop quickly you may be in trouble. Just looking out for you.
I agree. A doolie would be safer.
Seems like a pretty clear answer to me.
But from all of this sage advice, you conclude that your station wagon is the best tow vehicle. That just makes no sense.
If you're just asking the question because you just want to do what you just want to do, and you're looking for people to affirm your choice, then you should probably let us know that up front.
As I stated before, you can buy a brand-spanking new 1-ton dually for less than $40,000, with a full warranty, big 4-wheel power disc brakes, ABS, power steering, air-conditioning, power windows, tilt steering column, cruise control, power door locks, a 6-speaker audio system with blue tooth, a 7" touch screen, a rear-vision camera, an Eaton locking rear diff, full-floating drive axles, load range "E" tires, a 2.5" hitch platform, trailer wiring, integrated trailer controller, heavy-duty 6-speed lockup automatic overdrive transmission, heavy-duty engine oil cooler, 150-amp alternator, heavy-duty transmission cooler, 4.10 rear end gearing, and a standard 360-horsepower Vortec 6.0 V8 gas engine.
Old 09-22-2018, 02:11 PM   #64
Ed Wright
Ed Wright's Avatar
That's just dan. Aske a question, half a dozen very experienced races take the time to tell him what we have learned, and he then tells us why we are all wrong, and tells us all what the correct answer (in his head) happens to be. All from his vast experience racing his IHRA Pure Stock car a couple of years. Why does he ask if he already knows everything? And, why do some of us still bother to try to help him?
Ed Wright 4156 SS/JA
Old 09-22-2018, 02:31 PM   #65
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
Ed, you’re just as guilty as myself and countless others; giving the benefit of the doubt. That’s one of the great things about class racers. First time I brought my stocker out I was vastly unprepared and it was probably pretty obvious, despite that a seasoned and successful racer lent me a hand (VanLant BTW). Learned my lesson, when I picked up my new car up north in May I drove back within 50 miles of a big combo race at TriState. Dan will undoubtably learn lessons as well, meanwhile we’re here to help. Sure bests posting BS on FB.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-22-2018, 06:00 PM   #66
6130
That's just Dan. Ask a question, half a dozen very experienced racers take the time to tell him what we have learned, and he then tells us why we are all wrong, and tells us all what the correct answer (in his head) happens to be. All from his vast experience racing his IHRA Pure Stock car a couple of years. Why does he ask if he already knows everything? And, why do some of us still bother to try to help him?
Got it...
Old 09-23-2018, 04:41 PM   #67
MR DERBY CITY
Liked 7,936 Times in 1,518 Posts
ED, you flat nailed it....
Old 09-23-2018, 08:15 PM   #68
Jeff Niceswanger
Liked 1,031 Times in 368 Posts
These towing stories take me back to one evening, more like early morning, over in Chicago. Somewhere around 1998 or 99,, we switched from local bracket racing to the divisional stuff. I purchased a 1977 Coachman Leprechaun motor home. A whopping 22 foot long. We also purchased a 26 foot Haulmark box trailer ( The one we still have) .The Coachman had been garaged in a barn its entire life, and was in amazingly good shape. But it had a very anemic Ford 460 200 HP / 350 FT LBs TQ engine. So I get the idea I going to make this super duty tow vehicle and " Tim Taylor" it. So I take out the engine and head over to Platinum Engines. Todd Quinn, the owner helps me change pistons, carb, and intake manifold. He had some fun with it, milling the heads and CC'ing them to get a true 10 to one compression. He calls his buddy at Bullit Cams and they come up with a cam grind.It had 4.11 gears and only a 3 speed transmission so the cam they came up with was a little on the aggressive side , but said it would be a great pick for hilly terrain over here in eastern Ohio. I think 224 @ .050 comes to mind ... While we are waiting on push rods to come in, I had a buddy install a huge Dyno Max exhaust system. After we get it built, Todd wants to dyno it, so we do. 357 HP and 505 Ft lbs of torque. We get it all installed in the Motorhome, and to our delight this thing sounds like a Super Comp car.. At 800 rpm it idles with authority.In that little MH, this thing would fly. Took it out for its madden voyage with 10 thousand lbs of car and trailer on the back, and headed over to the West Virginia line to the biggest hills around. It topped those babies at 65 mph!. We're happy as heck, and we turn around and come home....That's when something very ugly reared its ugly head .. BREAKS ! . The old girl had drums all the way around, and stopping that much weight, was not going to be something it was very good at. We towed all over the eastern US in that old rig. The Coachman Hilton we called her. Honestly, its a wonder we weren't killed in it. Many a night I got off work at 5 and brother John and I headed for St louis , or Chicago, or Bristol. 8 and 9 hour tow's .. Travelling all night in that old MH was always good for at least one white knuckle ride. Not only did big semis just blow you right into the rumble strips every time one went around ya, but at least once a trip, we would have one of those " OH SHEEEET" and bout hit someone in the caboose ..
Getting back to my Chicago story. It was 4 or so in the morning, and we are close to getting to the track at Chicago. We have our CB radio on, and are scootin down the interstate when we get into what I wanna call "whoop de do's " . You know, interstate that sets your truck romping back and forth like a hobbie horse. We had been into them before, but these were kind of on the bad side.( For all you Division 3 guys, kind of like the staging lanes at National Trails used to be.. LOL ) I could feel the front end getting light, then as we bottomed out in the lane... having full control again. No big deal, we just ride it out, just like all the times before.. Then the CB lights up ! Hey Bob , says this trucker . and he's almost shouting " HEY BOB,, YOU SEE THAT WESTBOUND CAMPER DOING WHEELIES !! ?? The WHOLE front end comes off the ground .. He's doing WHEELIES !". His buddy comes back and says " The one pulling that real long trailer with that wee little Motorhome ? ..His pal comes back and says " YEA WATCH "! Then as we do a few more pop ups for them they just freak out .Those guys thought they were witnessing the best thing since sliced bead, not knowing we do this **** every weekend all over the country in this crazy thing. Bottom line is, we all do what it takes to race, and sometimes we're just stupid …..
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 09-24-2018, 08:05 AM   #69
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Originally Posted by Lew Silverman View Post
Tow vehicle weight and axle ratio are two big factors, Dan. What you're looking for is Gross Axle Weight Rating (GAWR) which is the actual maximum weight on each axle and Gross Combined Weight Rating (GCWR) with is the total weight of both truck (with fuel AND cargo) and the fully loaded trailer. There are any number of variables the factory uses, but every truck has a recommended GCWR that must be taken into consideration. Are you going to be using a 5th-wheel or tag trailer? Different hook-ups will also effect the weight you can carry. You may also notice that the vehicles with higher tow ratings are equipped with steeper axle-ratio's, which will effect your fuel mileage. Take your trailer to a public scale and get a fully loaded weight as well as a tongue (or 5th-wheel) weight. Then compare those figures with the tow ratings for the Silverado. As long as you don't exceed those numbers you'll be fine!
http://webcontent.goodsam.com/traile...wGuide2018.pdf
Axle ratio turns out to be the biggest variable I have found.
I have a 2wd crew cab dually with 4.10 rear gears.
It has a max tow rating of 10,500 lbs.
Had someone just checked the 4.30 rear gear option when the truck was ordered the tow rating would have jumped to 13,500 lbs.
All other things are the same.
Same engine, trans, suspension springs and brakes.
Just a gear change can make that much difference as to what you can legally pull
Old 09-24-2018, 12:11 PM   #70
ALMACK
ALMACK's Avatar
Originally Posted by kdanner View Post
Have to disagree completely, I wouldn't think twice about a modern half ton truck towing that amount of weight. They have way more brake now, way more tire which lets the brakes really work, ABS that actually works without locking up tires, way more gears in the trans, heavier duty trans, heavier duty rear axles, tow/haul modes for the trans that really help via engine braking, fantastic OEM trailer brake controllers, trailer tire pressure monitoring. More capable than what a 3/4 ton truck was not long ago. Now I wouldn't feel comfortable with over 6 tons behind one like they advertise them being capable of, but 3, oh yeah, they'll do that very well.
I agree.
I recently made 2 trips to the track with my 2011 f150 4wd and the 5.0 Coyote engine.Towed great, braked well and got 15 mpg.
While the trailer was 5,000 lbs with car, the brakes on these newer trucks are far superior today than 1/2 tons from the 80's.
On the flip side, there's no way I would feel comfortable pulling my 7,500 lb. enclosed with the same 1/2 ton even tho Ford "rated" it for more.
That's what I have an F350 for
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
