Old 09-25-2018, 08:58 PM   #20
fastlane
Liked 53 Times in 20 Posts
Default Re: Factory Stockers FS/XX
For factory stock to survive NHRA needs to add it to way more then the 7 events it has now. There is not 1 event anywhere near the west coast. It is now a half country class. Also it will need to be available in the points meets. As it gets more popular there will be entry limits like in every other class. If it is not a class that you can run in a points meet in order to get grade points to even enter the FS/xx in the future at the national events, you need to drop 200 lbs out of your car to 3360lbs and that requires a completely different setup, so you have to convert your car to run FS/AA with a sportsmen lite and a breakout and a dial in to be able to get the grade points I know that is not a requirement now but that will change every year Chevy adds 69 cars Ford and Mopar 50 each so that's 169 more cars of which about 50-60 are XX supercharged cars. Also it would help if NHRA backed off on some of the changes allowed and keep it as close to how it came built to keep the cost down and give the average racer a chance to be competitive. When you turn it over to schumacher to add to all his professional teams what will chevy and Ford do the same then you have another Prostock. Right now the cost is 130,000 for the car 45,000 for the engine upgrade 35,000-40,000 for a transmission 7.50 cage and suspension and brakes. And that is before a motorhome and trailer and assorted equipment. A lot of money to spend to get to just a few racer or 7 if your willing to travel across the entire country. And still not be competitive with factory backed teams. NHRA needs to think this class through before it is ruined.
fastlane is offline   Reply With Quote
