Old 10-16-2018, 08:12 PM   #1
nolongerracing
Liked 72 Times in 27 Posts
Default Re: 360 mopar oiling
If you are using the newer R block that has the lifter valley closed off, you need to provide more drain back to the pan. Also check the oil filter mounting boss. That area is different than the stock blocks and you will need to add an extra cork gasket between the plate or adapter and the block. If you are running the filter plate, make sure it has 6 or 8 holes and not 4 as some plates do.
nolongerracing is offline   Reply With Quote
Old 10-17-2018, 12:01 AM   #2
older racer
Liked 68 Times in 26 Posts
we use a smaller filter, ph 43, adds oil to pan. 5 1/2 quarts. total. no issues/ also,full groove mains.
older racer is offline   Reply With Quote
Old 10-17-2018, 12:41 PM   #3
CMcAllister
Liked 920 Times in 259 Posts
I've run stock crank 360s to 7300-7400 in a non-Stock application with multiple style big pans, cross-drilled crank, accu-sump, System 1 filter, big pump, 002-0025 clearance, etc. etc. and still knocked the bearings out of it. The issue is getting oil on the crank and keeping it there instead of being bled off to other places, like the left galley, and the cam and heads. You have to fix the block, specifically the oiling system, and keep the oil on the crank. Some of the stuff I've done isn't legal for Stock. Are bushed lifters and/or non-OE plumbing in the lifter valley legal?
Old 10-17-2018, 01:30 PM   #4
tstickff
tstickff's Avatar
Liked 561 Times in 138 Posts
If you use a windage tray take it out, same with a crank scraper, and the biggest difference you can do is use the oil accumulator, i had the same issue until i used the oil accumulator.
Tim
Tim Stickles
tstickff is offline   Reply With Quote
