Liked 341 Times in 67 Posts
It is more consistent from run to run. We use John Deere 303
Liked 482 Times in 159 Posts
I recall reading numerous posts about this on YB many years ago.
Liked 99 Times in 60 Posts
a respected/experienced converter builder tells me it "tightens" the converter 200 RPM. After some experimentation, I have settled on name brand Dexron/Mercon III. [that is to say, not a house brand] Valvoline, Pennzoil, Castrol, etc. The house brands, while OK for basic passenger car service, do not have the premium additive package to resist heat over time.
Larry Woodfin 471W |
Liked 172 Times in 81 Posts
The specific gravity of the fluid will have more influence on the stall speed than the viscosity. Synthetic fluids change viscosity less with temperature than dyno fluids so will be more consistent, look for a fluid built with group 4 base stock.
Confusing, yes, I do this stuff for a living. Jim Mantle V/SA 6632 |
A friend of mine here in gonzales la been running that !!! Keith hunter w powertrain specialist !!!! Works gd !!! Js
Liked 424 Times in 50 Posts
I long time friend and serious bracket racer who owns a trans shop told me it does run a little more consistAnt but if you get into close back to back runs it doesn't stay as cool as regular trans fluid
Liked 369 Times in 127 Posts
I run the John Deere Hygard fluid in mine ( $ 17 a gallon)
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#8 | |
Anyone else with a similar experience in a small engine Stocker? Best place to buy?
Liked 333 Times in 180 Posts
Just remember if you use TDH in a trans make sure you use the winter blend ---it is clear whereas the summer blend is "Orangish" in color---you can buy JD TDH at most farm supply stores , some Walmarts sell it also Autozone Napa etc& other auto parts stores can get it for you too--- stuff works great in rear ends too---race only not on the street rears
Liked 132 Times in 52 Posts
I was told by a great super stock racer that's no longer with us to use John Deere TY22000. He said with atf fluid he changed it every 50 passes and the John Deere he put it in and ran it 150 passes when he would pull trans to freshen it. I ran it in a bracket car with a ford C4 with great luck and that's what he ran also. I just built a fresh C4 for a street truck put it in it but hasn't been long enough to tell how it will workout on the street. Around a 1000 miles so far so good.
Terry |
