Old 10-19-2018, 04:55 PM   #1
L Peterson6261
Liked 38 Times in 13 Posts
Default Hydraulic Fluid in automatics
Would someone who has used hydraulic fluid in their automatic transmissions be willing to share the advantages and/or disadvantages to using it over regular ATF. - Thanks!!
Larry Peterson
Stk: 6261 B/SA
L Peterson6261 is offline   Reply With Quote
Old 10-19-2018, 05:17 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Hydraulic Fluid in automatics
I can not imagine what the advantage would be. Sure be interesting to hear.
Ed Wright 4156 SS/JA
Old 10-19-2018, 05:33 PM   #3
Mike Graham
Liked 341 Times in 67 Posts
It is more consistent from run to run. We use John Deere 303
Mike Graham is offline   Reply With Quote
Old 10-19-2018, 05:59 PM   #4
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
I recall reading numerous posts about this on YB many years ago.
Old 10-19-2018, 06:22 PM   #5
Dragsinger
Liked 99 Times in 60 Posts
a respected/experienced converter builder tells me it "tightens" the converter 200 RPM. After some experimentation, I have settled on name brand Dexron/Mercon III. [that is to say, not a house brand] Valvoline, Pennzoil, Castrol, etc. The house brands, while OK for basic passenger car service, do not have the premium additive package to resist heat over time.
Larry Woodfin 471W
Old 10-19-2018, 09:47 PM   #6
jmantle
Liked 172 Times in 81 Posts
The specific gravity of the fluid will have more influence on the stall speed than the viscosity. Synthetic fluids change viscosity less with temperature than dyno fluids so will be more consistent, look for a fluid built with group 4 base stock.
Confusing, yes, I do this stuff for a living.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 10-20-2018, 01:39 AM   #7
FLOYD RUSSO JR
Thumbs up Re: Hydraulic Fluid in automatics
A friend of mine here in gonzales la been running that !!! Keith hunter w powertrain specialist !!!! Works gd !!! Js
FLOYD RUSSO JR is offline   Reply With Quote
Old 10-20-2018, 04:56 AM   #8
Kenny Bomar
Liked 424 Times in 50 Posts
I long time friend and serious bracket racer who owns a trans shop told me it does run a little more consistAnt but if you get into close back to back runs it doesn't stay as cool as regular trans fluid
Kenny Bomar is offline   Reply With Quote
Old 10-26-2018, 08:45 AM   #9
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
I run the John Deere Hygard fluid in mine ( $ 17 a gallon)
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-26-2018, 09:46 AM   #10
Jeff Stout
Liked 704 Times in 281 Posts
I understood in using it to tighten a N/A converter that gets nitrous applied to it. With nitrous a converter becomes way to loose and with the hydraulic oil it will bring it back 3-400 rpm's
