Old 10-22-2018, 12:22 PM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Re: Turbo 400 experts please step in....
Originally Posted by ss3011 View Post
There are several companies that sell governor weights and springs to move the shift points around . You are correct that playing with the modulator won't get it done . The kick down solenoid basically bypasses the modulator circuit at WOT only .
I knew that if you saw the original post, you would have the answer, Russ. From what Pustelny tells me, there are very few people who know GM automatic transmissions as well as you.
Old 10-22-2018, 01:40 PM   #2
Jeff Stout
Liked 704 Times in 281 Posts
https://www.hotrod.com/articles/hppp...ing-turbo-400/
Had someone use this to adjust RPM
Old 10-22-2018, 01:42 PM   #3
Jeff Stout
https://files.dpbrands.com/bm/instructions/20248.pdf
