Liked 73 Times in 36 Posts
Mr Smith et al,
I have run across a lot of these type stuck jets from some over zealous dude overtightening the jet(s). Whenever I can't get the impact tool approach to work, I just drill the jet and use an appropriate sized (#2 or #3) ezy out tool. That method has always worked and I always run a tap through the threads afterwards. Of course it ruins the jet, but new jets are cheap compared to losing a carb casting through hammer and tong approaches. Jets shouldn't be tightened to much more than about 40 inch-pounds anyway. ![]() Hope that helps solve the problem for you. Good luck. Regards, HB2 ![]() |
Liked 972 Times in 195 Posts
Tried all the above suggestions to no avail.The jet next to it was tight also.Got it out with a little heat from a heat gun.Finally had to drill it out in steps.Im pretty sure it had been cross threaded in place at one time.Maybe even from the factory.Thanks for all the suggestions.
