Old 11-01-2018, 05:17 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Re: Before I put this on
Originally Posted by CMcAllister View Post
ON is open in either direction. OFF is closed stopping oil from moving to the engine while allowing it to charge the can until pressure is equalized with engine pressure. Having the valve ON while on track, as opposed to using a pressure switch, allows the accumulator to "catch" a sudden pressure drop before it reaches a low point and keep the galleries full, since the can is charged to engine oil pressure. Having it open all the time requires the oil pump to recharge the can every time the engine is started since it will dump into the engine with the valve open. An electric valve also allows mounting in places that may be difficult to get to in order to operate a manual valve. I quickly found it inconvenient to have to start the engine, allow the can to charge, close the valve and shut the engine off at the end of the day. Just my experience with it.
Do you have a separate switch for the unit or just tie into the ign switch? Engine running, it's open, engine off, closed?
Old 11-01-2018, 05:51 PM   #2
CMcAllister
Liked 920 Times in 259 Posts
Separate switch. My switch panel has 2 fuel pump switches with only one pump. Used the unused switch to operate the accusump. Just personal preference to be able to control the valve and not have the thing dump 3 qts into the engine to be whipped up by the crank and then pump it all back into the can every time its shut off and started. Not concerned about uncovering the pickup unless it's on the track.
