Old 11-05-2018, 03:18 PM   #1
Mike Jones
Liked 684 Times in 289 Posts
Default Re: Man. trans for Stock
Originally Posted by Don Anderson View Post
Liberty Gear 5-speed with the Long shifter.
They will get you the trans ratios you need for your combo.
"Man. trans for Stock"
...4 speed only
Old 11-05-2018, 03:41 PM   #2
Mike Mans
Liked 299 Times in 48 Posts
You can run a 5 speed manual in stock if the vehicle came from the factory with a 5 or 6 speed manual. It just has to be clutch assisted, not clutchless in design.
Mike Mans is offline   Reply With Quote
Old 11-06-2018, 07:52 AM   #3
Mike Jones
Thanks Mike,
I don`t know why, but I assumed Tony was running 1st gen Camaro.
Old 11-06-2018, 11:24 AM   #4
Mike Mans
Thanks Mike,
Sorry Mike, I was just clarifying for Don Anderson's example - I wasn't thinking about Tony's original post question. Don runs an 80's Fox body that is eligible for a 5-speed where you're completely accurate that Tony (presumably in a '67-69 Chevy) can only run a 4-speed.
Hope that wasn't too confusing!
