Liked 9 Times in 5 Posts
Who makes a good dip stick for a metric 200? TIA
Liked 4 Times in 2 Posts
Masta performance
Liked 974 Times in 310 Posts
Lokar
Liked 799 Times in 236 Posts
Lokar is a good one. Double check the markings on the dipstick, though. -Al
"That'll never work....." |
Liked 883 Times in 237 Posts
Lokar is nice because of its flexibility ,However they do fill very slowly .
As Alan said check the calibration . It doesn't matter who makes them every one I've ever checked was wrong. Here's a bulletin from Turbo Action on the correct calibration
Liked 13 Times in 10 Posts
Jack Sepanek, he will make one that is accurate
Liked 706 Times in 283 Posts
Good to know as I have to drop my pan as it leaks from the cork gasket I installed dry.
Liked 254 Times in 78 Posts
If you use a LOKAR, you may have trouble installing on the trans end. The plate between the case and valve body on my metric 200 was sticking out and preventing the installation. I had to drop the pan, valve body, and plate and trim the plate. Just had to trim the corner off the plate.
Mike Moller NHRA 203 Q-R-T/SA |
