Liked 280 Times in 139 Posts
What is the valve lift on the int. and exh.?. gsa612
Liked 237 Times in 126 Posts
If you can find a comparable spring on the PAC Racing site, this link to their spring rate calculator might help.
https://www.racingsprings.com/index..../?sku=PAC-1224 Edit: Change the part number to your match.
Liked 239 Times in 114 Posts
The basic formula is F=kX . F is the force , k is the rate , X is the difference in spring height from the length of the spring when it is not loaded .
#4 | |
Liked 777 Times in 142 Posts
To add to above, the spring rate is stated as the force generated per unit of compression. Ex: 1,000 Lbf/Inch, 1,700 N/cm etc. Also, its spring FORCE, not pressure. Spring pressure is a common misnomer racers seem to always use, and it just wont die. Its entirely wrong. Its not a pressure, Its a force. |
Liked 165 Times in 59 Posts
The Pac 1220X spring shows 160 lbs seat press.at 1.900 and 400 lbs open at 1.250 which is close to coil bind.If you subtract your lift of .450 from the 1.900 your at 1.450 open.That may give you only 360lbs press.You need to find a "short" spring with your low lift that will give you the open pressure your looking for.Even if you do find a long spring that gives you the numbers, but is .300+ from coil bind your going to have valve stability issues. Have you looked into Comp cams ?. gsa612
What's the application here? It doesn't really make sense to talk pressures when we don't know what is being asked of the engine. I run PAC 1427 springs - conical for a BBC - in a SBF with NASCAR type iron heads. Stuff gets mixed up when all you want is GO...
Note: A PAC 1409x at 1.8 will give you pressures of 175/384. I'd give up on a 1.78 IS, it's too hard to shim to. 1.8 or 1.85 are common. Note 2: What is the seat size? Ask questions and give info. I didn't so I have 4 sets of springs now............
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 12-10-2018 at 11:24 PM. |
