Old 12-11-2018, 10:38 PM   #1
GTX JOHN
Liked 2,493 Times in 700 Posts
Default Re: 904 transmission
Pro Trans builds ALL ours!
Ratio depends on weight and altitude you run at and a
couple other things....Not set in Stone!
John Irving
741 Stock
741 Super Stock
Old 12-12-2018, 09:41 AM   #2
mykids
Liked 2 Times in 1 Post
I spoke to Joel yesterday- a real nice down to earth guy whom is extremely busy (68 Factory Stocker Trans to do) we will talk again at his convenience about a 904 but a nice guy without a doubt - must be a well kept secret or I have been an ostrich but thanks for the referral
mykids is offline   Reply With Quote
Old 12-12-2018, 05:19 PM   #3
Mopar 340
Liked 6 Times in 4 Posts
I’ve heard many good things about pro trans. Planning on giving them a call soon! Thanks for the helpful info!
Mopar 340 is offline   Reply With Quote
Old 12-12-2018, 06:44 PM   #4
cummins
Liked 27 Times in 8 Posts
Thumbs up Re: 904 transmission
Yes pro trans is building me one now for a 340 combo
cummins is offline   Reply With Quote
Old 12-12-2018, 09:40 PM   #5
S/ST 3040
S/ST 3040's Avatar
Does anybody have a Pro Trans list of letter codes and available gear ratios?
Edit: I found the link in the fine print on their website.
S/ST 3040 is offline   Reply With Quote
Old 12-13-2018, 08:15 AM   #6
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
Just FYI that on insidecompracing.com you can go to the classified section and generally find some 904 gear sets and trans for sale. Many of the comp folks run Pro Trans.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-13-2018, 12:14 PM   #7
Jeff Teuton
Liked 325 Times in 50 Posts
We use Pro Trans. We like the 727 SB more than the 904. Has a few different parts and deeper pan doesn't hit the rotating assembly. You probably need a 2.65 to 275 first.
Jeff Teuton 4022 STK
Old 12-13-2018, 06:21 PM   #8
Mopar 340
I’m thinking 2.75 I want to get off the line much quicker than I am now.
Old 12-14-2018, 12:00 AM   #9
GTX JOHN
You can try 2.75 inexpensively......They came factory in many late model
904s. They are not straight cut BUT a Huge improvement over 2.45 in a small block.
John Irving
741 Stock
741 Super Stock
Old 12-14-2018, 05:15 PM   #10
Duster 7695
Liked 8 Times in 6 Posts
Pro Trans just did a 904 for my Aspen with a 360. He decided on a 2.61 first and 1.61 for second gear.
Raul
Duster 7695 is offline   Reply With Quote
