Old 12-21-2018, 09:08 AM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Oil pan for 3rd gen f body SBC
Originally Posted by Eman View Post
I used a Milodon, but not thrilled with the kickouts on the sump and full length headers.
What other pans will fit? The competition products one measures 10.5" long at the sump, will tat fit the factory K member? Hamburgers is the same. I called Stef;s and they said their B&B 91088 was to deep at the front and it would hit the K member.
That Moroso is nice, just a little pricey.
I had a Milodon, it hit the ground on landing, if the wheel stand was very high. Ended up too close to the oil pump screen. Moroso has not hit so far.
Ed Wright 4156 SS/JA
Old 12-22-2018, 10:48 AM   #2
brian schuetta
Liked 28 Times in 15 Posts
I have a Milodon laying around that was on the last Stocker 305 I had built. Remember it fit well. The 305 didn’t catch much air in the Camaro. I’ll measure the Comp Products pan next week I’m in El Paso headed to Chicago and Milwaukee next.
brian schuetta is offline   Reply With Quote
Old 12-23-2018, 08:07 PM   #3
brian schuetta
Are we talking NHRA Stocker legal or other?
Old 12-24-2018, 08:20 PM   #4
Eman
Liked 133 Times in 76 Posts
My car is strictly a bracket car with a stock K member and solid Moroso mounts.
Old 12-31-2018, 10:48 AM   #5
brian schuetta
I made a sketch of the pan and K-member clearances. From front of pan to sump is 11". Distance between front of sump and K-member is 1". Distance between bottom of pan, non-sump area, is 1/4"-3/8". Not sure if the sketch will attach.
Name:	Oil Pan Sketch.jpg
Old 12-31-2018, 11:07 AM   #6
Eman
Thanks for the sketch! I see it's pretty tight between the pan and K member, are you using solid motor mounts?. I'm debating notching the K member when I have the motor out.
Again thanks for measuring and have a Happy New Year!
Old 12-31-2018, 02:52 PM   #7
brian schuetta
Solid Moroso motor mounts and stock K-member.
