#31 |
Liked 239 Times in 114 Posts
Just wondering if we are comparing apples to apples . The WIX filters I use which has the R after the number has a metal screen that backs up the filter media . I used to use the HP version of the Fram filter , which I never had a problem with . When I get out to the shop , I will cut apart a Fram HP filter and see how the filter media is attached to the bobbin . I know the can is thicker than the street version .
#32 | |
Liked 8 Times in 7 Posts
be a nice guy and post some pics?
without losers,winning means nothing. |
#33 |
Fram sells because of their strong marketing program.
Nevertheless, the problem with Fram oil filters has been the inconsistency of their product because it is manufactured all over the world without proper quality oversight. In my past business travels I have drive by Fram oil filter manufacturing facilities from South America throughout Asia. They have also had a high number of oil filter recalls throughout the years, including their racing oil filters in 2007 as shown in the link below: www.motorstate.com/pdf/FramRecall.pdf |
#34 |
Liked 169 Times in 53 Posts
wlile I agree that the fram street filters are junk I've used the fram hp filters for a long time and never had any problems. I cut every one open when I change them and their quality seems to me to be as good as the napa's or the wix. I know the frams are a lot easier to get than the others.
Bill Bogues 4696 STK |
#35 |
Looks like the construction is the same as the street version . End caps are cardboard , the bypass valve , under the screen looks well designed with a coil spring .
#36 |
Liked 2,336 Times in 464 Posts
About 5 years ago I bought a 74 corvette that was running in stock. I had a motor built for it and decided to have a straight rear put in it along with some other changes. The motor was done before the corvette was finished. I wanted to race at Indy and put the motor in my brother's Camaro and went to Indy. We raced it a few more times and put it away for the winter. I put the motor In the corvette and went to a race the next year. Made a pass and only had 10 pounds oil pressure. After putting another gauge on dropping the oil pan and chasing other stuff someone suggested we change the oil filter after asking if it was a fram. Yup the racing filter. Changed the filter and bam 40 pounds preasure and a .10th in ET. Fram = Junk!!!!!!! BP
#37 | |
Liked 7,941 Times in 1,520 Posts
#38 |
Liked 53 Times in 38 Posts
I've been reading along and I'll voice my opinion (whatever that's worth).
An oil filter on a "drag car" is like following behind a baby with a paper towel that has no diapers on. Screens and magnets will catch the iron, aluminum and babbitt usally won't hurt anything. Change the oil often and inspect. If the filter gets a little clogged it will bypasses the element, so non filtered oil gets thru. I'll not run one (free hp) we'll see how it works. Mike |
#39 |
Liked 920 Times in 259 Posts
Years ago while still in a dealership, we had a spat of issues with a particular 4 cylinder OHC engine seizing the cam in the head. The common thing between all of the failures was a Fram filter.
I've always used a System 1 type filter in a race application. I know the filter rating stays consistent since it is reused, I know what's normal and what's not, and I use the ability to look at it often at no cost to pay close attention to the engine. I have caught several issues before they became a major problem by doing so as a part of my weekly maintenance routine. |
#40 | |
Liked 2 Times in 2 Posts
