Old 01-08-2019, 08:06 AM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Attn. 265 Racers.What block is the best?
That was about 50 years ago. I didn't take pictures of everything like many do now. Would have to screwed with having them developed too. LOL
Ed Wright 4156 SS/JA
Old 01-08-2019, 10:41 AM   #2
Coleydog
Liked 53 Times in 38 Posts
You sure got that rite, pictures where a luxury back then till the disposable camera and 1 hour developing huts came along. Anyone under 40 wouldn't understand LOL
Old 01-09-2019, 10:42 AM   #3
carl hinkson
Liked 18 Times in 10 Posts
I have a 57 block that ends with the letter C that has been magged and cleaned, Also have a brand new small journal 3 inch stroke crank.
57 blocks had no side motor mounts.
carl hinkson is offline   Reply With Quote
Old 01-09-2019, 12:10 PM   #4
Ed Wright
Ed Wright's Avatar
Side mounts did not show up until 1958.
Old 01-09-2019, 05:32 PM   #5
55 Chevy
55 Chevy's Avatar
Liked 14 Times in 13 Posts
The block I run in mine is a 3720991(1956 number) but it has the neoprene rear main seal so it must have been a service replacement unit. No side mounts.
The '57 265 is a 3731548 and the number on the passenger side(on the pad in front of the head) can be either a "C,CD or CE". Mine is a "CD" which I believe meant it came with a 3 speed overdrive manual transmission. The car it came out was a 2 door wagon.
I think "CE" meant heavy duty clutch.
I call it a "Poor Man's" Bow Tie block.
Crank is part #3735236.
None of the 265's I own have side mounts.
55 Chevy is offline   Reply With Quote
Old 01-11-2019, 09:08 AM   #6
Bruce Witherspoon
Bruce Witherspoon's Avatar
Liked 5 Times in 3 Posts
https://lansing.craigslist.org/pts/d...780189148.html.
Bruce Witherspoon 3656 SS/KA
Bruce Witherspoon is offline   Reply With Quote
Old 01-11-2019, 10:56 AM   #7
Lyn Smith
Liked 959 Times in 192 Posts
Smile Re: Attn. 265 Racers.What block is the best?
Thanks for the link Bruce.I have seen 265 blocks/ complete engines from $100. to $1399. Depends on if it is for a Corvette or not.LOL I have a line on a 548 block that the owner says sonics .300 on the thrust side.Hope to get that one.Thanks everyone for all the info, and interest.I will let you know how it turns out.Will post build on the Racer Build Up thread.
Lyn Smith is online now   Reply With Quote
Old 01-28-2019, 04:16 PM   #8
Monte Howard
Monte Howard's Avatar
Liked 66 Times in 22 Posts
Lyn a friend of mine has some 265 engine parts for sale. 991 block, heads, crank and manifold. I told him to look you up on here. His name is Rob Fisher
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 01-28-2019, 05:02 PM   #9
Rob Fisher
Hi Lyn.....I have for sale parts from a 1955-56 Chevy 265 4bbl engine...
Intake # 3837109 J105 date........50.00
265 std block # 3720991..............50.00
Heads # 3703523 dated J204 and J264 50.00
std Crank # 6265 ...............................50.00
Distributor # 1110847..........................50.00
Manual trans flywheel 3703870..........25.00
timing cover w/ original flat head screws...25.00
Original water neck housing 370501B.....25.00
Fuel pump plate ,rod and factory marked bolts 25.00
Call or text 217-254-3115 ... Located in Humboldt IL 61931
WILL SHIP SMALLER ITEMS AND TAKE PAYPAL
Rob Fisher is offline   Reply With Quote
Old 02-14-2019, 09:37 PM   #10
Frank Castros
Liked 2,626 Times in 950 Posts
Lyn,
How much faster do you think the bogus but legal Turbo 400 or 350 is than the Powerglide?
