Old 01-17-2019, 04:36 PM   #1
Lyn Smith
Liked 986 Times in 198 Posts
Cool Jr Stock piston rules
I was reading a 1968 NHRA rule book today.It said under the engine rules that you could use any replacement piston "as long as it doesn't increase the compression generally the same in appearance".So on the 1955 265 engine with the flat top piston could you use a piston that had valve reliefs like the 56 and 57 engines had?
Old 01-17-2019, 07:25 PM   #2
Brian Fink
Liked 28 Times in 9 Posts
Default Re: Jr Stock piston rules
Unfortunately you have to make the 55 style work ; I believe CP is the only option as they made the first set for Carl Libucha after he sent NHRA a stock one.
Brian Fink is offline   Reply With Quote
Old 01-17-2019, 08:06 PM   #3
I would say yes. Probably wouldn't need them anyway, with the cams they had back then. Even if they did , they wouldn't work with the stock spring specs.
Old 01-18-2019, 12:24 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Lyn -
I saw the Weir Bros. '55 Chev station wagon go through a tear down in 1968 and those pistons did have valve reliefs. They passed.
Old 01-18-2019, 02:54 PM   #5
Lyn Smith
According to some vintage GM Parts Books I have, the flat top replacement GM pistons were discontinued in mid 1957,and replaced by the 56 57 piston with the reliefs.
