Old 01-28-2019, 02:48 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Royal purple 0-8w.
They say this oil is a little faster than reg oil. When I put it in can I run it all the time or does it hurt the motor to run this oil all the time? Thanks
Kdw1403 is offline   Reply With Quote
Old 01-28-2019, 06:51 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: Royal purple 0-8w.
You can do what makes you comfortable, but that is a very thin oil.
Will it make a little more power? For sure. I would save it for heads
up runs when you need a little help, and run something a little
safer for everyday racing. i.e. hot weather, hot lapping, late night
moisture, etc. Just my thoughts. J.R.
J.R. Haddad is offline   Reply With Quote
Old 01-28-2019, 06:57 PM   #3
FED 387
Liked 336 Times in 183 Posts
X2!!
Old 01-28-2019, 07:35 PM   #4
Ed Wright
Ed Wright's Avatar
X3! I know some Pro Stock cars run it all the time. Different deal there.
Ed Wright 4156 SS/JA
Old 01-29-2019, 08:31 AM   #5
nhramnl
Liked 358 Times in 83 Posts
X4. For me, just not worth the risk and expense.
Old 01-29-2019, 09:03 AM   #6
JohnRoderick
JohnRoderick's Avatar
Liked 11 Times in 4 Posts
http://rehermorrison.com/tech-talk-6...ee-horsepower/
JohnRoderick is offline   Reply With Quote
Old 01-29-2019, 09:09 AM   #7
Alan Nyhus
Liked 800 Times in 237 Posts
There's a balance between those thin oils and the rod/main clearances. Clearances that work fine for 'normal' oil viscosity (5w20, 10w30, etc.) can get you into trouble with the lighter viscosity oils. And the clearances needed to run the lighter oils...all the time... can paint you into a corner if you want to use the heavier stuff.
Do your homework and make sure to involve your engine builder. -Al
"That'll never work....."
Old 01-29-2019, 07:21 PM   #8
J.R. Haddad
Al we have had a few people around here build very tight clearance
engines, some with smaller bearings etc. where they needed to run
thin oil only. Haven't seen one that lasted the race weekend yet, and
for some that was after very long tow. As I mentioned above, thin oil
in a regular clearance type engine is only meant for that one heads
up run that matters. After that, get the regular stuff back in there.
Don't get lazy and leave it in there. J.R.
Old 01-29-2019, 09:13 PM   #9
Ed Wright
Ed Wright's Avatar
I have shown up where I thought Class would be tough with the zero weight Royal Purple oil already in it. For various reasons, left it in for eliminations. Ran it all weekend. Not crazy about the low oil pressure at a warm idle, but saw Zero other issues.
If you are having to pay someone else to build your engine, you might want to ask them about it. They know your oil pump & bearing clearances.
Old 01-30-2019, 09:04 AM   #10
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I once tried RP very thin oil in my Firebird Stocker.
Oil pressure would drop to near zero at low engine rpms...
I Dumped that oil out after 1 race weekend.....and it was no faster than what I was using before.....Mobil 1 10-30 or 5-30.....and oil pressure was always good with the Mobil 1 and it was faster than most other typical oils.....
Rich Biebel
S/C 1479
Stock 147R
