Liked 99 Times in 21 Posts
Liked 99 Times in 60 Posts
The tech sheets show the valve works with an idle vacuum above 7" Most of our stockers or super stockers do not have 7" vacuum idle.
Larry Woodfin 471W |
Liked 2,727 Times in 961 Posts
Interesting subject, I hope more with contribute to this thread.
#4 | |
Liked 101 Times in 52 Posts
Remember those NASCAR and other intakes with the drilled out mounting studs? This is a lot bigger hole. |
[QUOTE=Bobby DiDomenico;581432]Who says it has to work? (Or work as the emissions system was designed?;-)
Yeah, and nobody ever clipped a spring, with a restricted engine that, naturally, pulls manifold vacuum @ WOT, right?
Ed Wright 4156 SS/JA |
Liked 53 Times in 38 Posts
Just like another throttle blade, kinda bad mixture at idle but wide open a good increase, just richen up the jets. Big breather on other valve cover, not much oil spray. Would be interesting to see what cfm goes thru it. I can see why tech would shoot it down.
I have heard of guys using epoxy & a drill to convert the PCV hose nipple from manifold vacuum, to "ported" vacuum, which only pulls air with the throttle blades open. Just heard stories about that. Don't really know.
Liked 12 Times in 6 Posts
I had one that rattled when I shook it. I thought it was broke "So I fixed it".
