Old 02-01-2019, 11:39 AM   #11
Bobby DiDomenico
Liked 101 Times in 52 Posts
Default Re: Adjustable PCV Valve
Originally Posted by Dragsinger View Post
The tech sheets show the valve works with an idle vacuum above 7" Most of our stockers or super stockers do not have 7" vacuum idle.
Who says it has to work? (Or work as the emissions system was designed?;-)
Remember those NASCAR and other intakes with the drilled out mounting studs? This is a lot bigger hole.
