Old 01-29-2019, 11:34 PM   #1
BTR69
BTR69's Avatar
Liked 74 Times in 24 Posts
Default elgin 920p camshaft
Looking for input on a new, in the box camshaft I found in a stash my brother had. Elgin, 920P , "pro stock" grind, found info that shows it has duration 230/230 @ .050, lift .480/.480, 109 LC. I have a spare small block I plan to give some attention to sometime soon. Anyone have info that would be useful with this?
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 01-29-2019, 11:46 PM   #2
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: elgin 920p camshaft
those single pattern camshaft like that work well in street combinations for small blocks.A little soggy on take off but pull good from 3000 on. A little raspy on idle make for a nice sounding street machine'
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 02-06-2019, 05:05 PM   #3
Ed Wright
Ed Wright's Avatar
Default Re: elgin 920p camshaft
And, I have never seen an Elgin cam run anything like a Comp, Lunati, etc.
Might advertise that thing in something like BarganPost, etc.
Ed Wright 4156 SS/JA
Old 02-06-2019, 08:00 PM   #4
pmrphil
Liked 348 Times in 152 Posts
That sounds like a copy of the "Duntov 30-30" cam. The advice from Ed is about right.
Phil Molski
PMR Performance
S/C 1623
Old 02-08-2019, 12:14 PM   #5
Ed Wright
Ed Wright's Avatar
Evidently there is more to lobe profiles than many understand.
Old 02-08-2019, 09:44 PM   #6
BTR69
BTR69's Avatar
Thanks for the input Ed. Sounds like I'd be better off putting something better in the spare parts engine I plan to put together. I have a friend with a cool rat-rod that might be able to use this one, to give it a little more thumpy sound than the stock piece it has now. He's not as concerned with performance as he is the cool factor of it. Maybe I'll give it to him.
William Kilduff
1968 Camaro SS/C
Old 02-12-2019, 04:35 PM   #7
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Just came across a build using that Elgin 920p cam in a 327 +.030 that made 391hp. It was in a 2008 Chevy Hi-Perf magazine. Flat top pistons, Dart Sportsman 2.02 /1.60 heads and a Dart dual plane manifold w Holley 650. They used 1.7 ratio roller rockers as well.
Old 02-14-2019, 01:56 PM   #8
monte385
Liked 27 Times in 19 Posts
I'd think that cam would be comparable to a popular Comp magnum 280.
Comp sold a lot of those.
monte385 is offline   Reply With Quote
