Liked 24 Times in 13 Posts
Does anyone know, or has anyone measured, how much
current a starter solenoid draws. Terry K |
Liked 81 Times in 45 Posts
I have never checked how much amperage a solenoid draws. That being said, it should be only a few amps depending on if it a Ford or GM solenoid. A old school GM would be the most.What it is energizing is what is going to cause the most amps drawn. Modern permanent magnet starters will draw about 150 amps while cranking. That would be on a small block engine with 10 to one compression. The initial amperage draw would be about 20 to 25 amps more.
I always thought that the solenoid was basically a relay.
This relay closes a set of contacts that allows the/a battery wire to engage the starter. If this is true, the actual solenoid should only require enough current to keep it engaged. I suspected an amp or less. Terry K |
Liked 249 Times in 48 Posts
FED is correct given a few amps either way. It acts like a relay but it is not.
Pete |
Liked 99 Times in 60 Posts
To be more specific, a Ford starter solenoid and a GM solenoid or a typical aftermarket mini starter solenoid are all different in design and different in amp draw.
*The Ford solenoid/relay is, as stated above, only "making" a set of high amp carrying contacts. With this design, the amperage load is small, only a few amps. *The GM factory style solenoid serves two purposes. First, it engages the starter drive mechanically through a lever link that is moved to engage by magnet action from the solenoid. Second, it "makes" the contacts that power the starter motor. As stated above, this design draws much more. *The popular mini-starter design is like the GM dual function but does draw somewhat less load because of design differences. *Just for info, another solenoid design it the 100% duty cycle style. This is what we use when installing the solenoid activated master switch.
Larry Woodfin 471W |
#7 | |
Liked 133 Times in 76 Posts
Another thing that comes into play especially on a GM starter mounted solenoid is the heat. |
Eman has a good thought in ref to factory wire size. A SWAG could be ascertained in that Ford has an 18 gauge wire to bring in the solenoid whereas GM employes a 12 gauge wire.
Liked 237 Times in 126 Posts
i have one of those red MSD starters that probably came off a 747 based on the torque it provides. It doesn't require a Ford style relay/solenoid and has a wiring diagram that allows a 12 gauge wire to basically be connected directly to a start switch. Only problem was that this provided for the big wire on the starter to be connected directly to the battery at all times when the car was on. My steering shorted it out making a hard turn to get to the staging lanes. Burned out a 150 amp cutoff switch. I wound up wiring in a Ford solenoid to manage the battery power during start. My current headers won't clear the starter and I don't miss the drama.
On a side note, I have found that continuous duty Ford style solenoids make very good relays. They cost more but are very reliable. Another trick: If you use a Ford style solenoid fender mounted to send power to the starter, there is a reverse voltage surge that travels on the small wire back to the starter button when the switch is released. This is caused by the collapse of the magnetic field in the solenoid and can damage the starter switch or wire to it. I replaced a push button with thin gauge wire with a beefy momentary toggle switch and 14 G wire because of this. You can also wire a diode in that small wire to block reverse current if you understand those things.
#10 | |
Liked 165 Times in 59 Posts
if you have a good multimeter it has to capability to measure the amp draw thru a amp clamp to add if your starter motor is seasoned it will draw more amps to operate |
