Old 02-12-2019, 10:48 PM   #1
Chris Hill
Liked 244 Times in 26 Posts
Default Re: Solid lifters in Stock
When did this rule change happen?
Chris Hill
Old 02-12-2019, 11:43 PM   #2
2018, I believe.
Old 02-13-2019, 07:59 AM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Mark, newer Onan V twins(air cooled) engines are built by Subaru-Robin from what I know...…..They are 60 degree overhead valve engines used in 5.5 and 7 kw RV generators. Valve lash spec is .002-.003...
They usually get loose on the lash and not tight. They routinely fail from heat working on the valves, springs, guides and eventually the guides get loose in the head. Real bad problem on those. I replace heads on them all the time...….The hotter they run the quicker and more likely the guide problem will happen.....And owners that don't change the oil often enough. 2 quarts is all they hold.
Rich Biebel
S/C 1479
Stock 147R
Old 02-13-2019, 11:17 AM   #4
Pat6868
Liked 93 Times in 29 Posts
I ran my 327/275 stocker engine with plugged hydraulics at .005 lash cold. It did not like any tighter.
Pat6868 is offline   Reply With Quote
Old 02-13-2019, 03:53 PM   #5
SSDiv6
The ramps on camshafts on hydraulic and solid cams are designed differently for many reasons.
Due to the various ramp and lobe designs in Stock Eliminator such as dwell and non-dwell lobes, when you plan to switch from hydraulic to solid, the best is to talk to the camshaft designer at the camshaft company; not the salesperson.
If you are building a new engine, just have a new camshaft made for use with solid lifters. It will have the proper area under the curve and also, with the right lobe, you can create lofting that will provide the engine with more lift than what the actual cam was physically designed with.
Yes, due to the dynamics of a solid lifter, they tend to make more power and RPM quicker when compared to a normal hydraulic lifter only if the valvetrain geometry has been optimized. When I say normal hydraulic I am not talking about a restricted travel or blocked hydraulic lifter.
Also, a solid lifter will be lighter than a hydraulic counterpart. I always recommend EDM drilled solid lifters that are DLC coated, installed with the proper lifter bore clearance.
Many years ago during a conversation with Don Tweles at General Kinetics, he shared that his dwell lobes could be run 0.006 ~ 0.010 with solid lifters.
Old 02-13-2019, 08:42 PM   #6
Rob Petrie E395
Liked 216 Times in 77 Posts
Thank You to everybody who replied since I revived this thread. I'm going to give it a try. I've got to do something to find some ET. Hopefully this, a 200 transmission and a couple other things will help get me going In the right direction.
Old 02-15-2019, 04:12 PM   #7
Chris Hill
2018, I believe.
Thank you,
Chris Hill
