#21 |
Hi Lyn.....I have for sale parts from a 1955-56 Chevy 265 4bbl engine...
Intake # 3837109 J105 date........50.00 265 std block # 3720991..............50.00 Heads # 3703523 dated J204 and J264 50.00 std Crank # 6265 ...............................50.00 Distributor # 1110847..........................50.00 Manual trans flywheel 3703870..........25.00 timing cover w/ original flat head screws...25.00 Original water neck housing 370501B.....25.00 Fuel pump plate ,rod and factory marked bolts 25.00 Call or text 217-254-3115 ... Located in Humboldt IL 61931 WILL SHIP SMALLER ITEMS AND TAKE PAYPAL |
#22 |
Lyn,
How much faster do you think the bogus but legal Turbo 400 or 350 is than the Powerglide? |
#23 |
Liked 986 Times in 198 Posts
I really don't know Frank.Will do some back to back tests this spring.
#24 |
A 57 265 block will also have a pad for a block mounted starter motor that the 55-56 blocks don't/can't have; makes it a lot easier to bolt up a 3 speed automatic, and not have to use an adapter. Plus they have better oiling than the 55-56 blocks. Getting hard to find, and I have one I'm keeping. There is also a rope seal conversion kit to a neoprene seal, Best Gasket Seal #3711X. I am Butch/56sedandelivery.
#25 | |
What is the part number for those blocks? |
#26 |
Liked 20 Times in 15 Posts
