Liked 99 Times in 60 Posts
I am out of the loop in ref to BBC.
My first desire is to find a nice, standard bore, four bolt, 454 block that will run standard with a.001 - .002 hone. Beyond that, other than the original Mark IV design, what other BBC blocks will accept common BB parts
Larry Woodfin 471W |
#2 | |
Liked 18 Times in 10 Posts
Put a torque plate on a standard bore block you will not be happy with what you see, Reseal is key in making good power. |
#3 | |
Liked 230 Times in 106 Posts
Good luck finding a standard bore block. Most will need 30 or more. Check NHRA accepted product for blocks BUT they're not cheap. |
Liked 880 Times in 311 Posts
Larry,
The Gen 6 blocks are a lite by quite a bit, but pans, covers and lifters are different. Then the 2 piece rear seal adapter or 1 piece crank. I assume this is just for your bracket ride.. I have a Std 4 bolt Mark IV I have Decked, align hone and ARP main studs, no fill.. Might make std on some hi limit pistons. I will check it in the morning. I also have a short deck Gen 6 Marine. Siamese cyl. 4.53 bore, 9.780 deck, align honed w/2 piece seal adapter fitted and installed. No filler. All machine work is fresh on both ^^^.. I have a couple new Merlins and a Brodix in stock. You know I've got a shop full of good stuff. Call me.
Adger Smith (Former SS) Last edited by Adger Smith; 02-18-2019 at 05:25 AM. Reason: sp |
