Old 03-21-2019, 11:32 AM   #1
Default Adjustment - Factory Stock Showdown
From the NHRA tech department.....
NHRA Technical Department Makes Parity Adjustment to the SAMTech.edu NHRA Factory Stock Showdown
Based on SAMTech.edu NHRA Factory Stock Showdown performance numbers from the first race of the 2019 season, the NHRA Technical Department is increasing the supercharger top pulley size on the 2019 COPO 350 combination from 3.350 inches to 3.500 inches and the 2019 Cobra Jet 327 combination from 3.250 inches to 3.500 inches. This will decrease the 2019 COPO 350 combination supercharger overdrive from 147.5 percent to 136.6 percent overdrive or 10.9 percent. Additionally, this will decrease the 2019 Cobra Jet 327 combination supercharger overdrive from 146.2 percent to 128.6 percent or 17.6 percent. As a reminder, no other changes may be made to all approved superchargers, including, but not limited to: (upper or lower pulley sizes, gear ratios, cases, rotors, etc.). All other permitted combinations in the SAMTech.edu NHRA Factory Stock Showdown will remain unchanged. This rule change will go into effect immediately. NHRA reserves the right in the future to make additional rule changes to control performance and maintain parity in the category.
Old 03-21-2019, 02:44 PM   #2
Superfan1
Superfan1's Avatar
Liked 2,638 Times in 440 Posts
Default Re: Adjustment - Factory Stock Showdown
That didn't take long.
Bill Seabrooks - superfan1
Bridgeport, CT
Old 03-21-2019, 03:28 PM   #3
George Fitzpatrick
George Fitzpatrick's Avatar
Liked 94 Times in 24 Posts
About how much will they slow down?
George Fitzpatrick 426 HEMI STK, SS
George Fitzpatrick is offline   Reply With Quote
Old 03-21-2019, 04:15 PM   #4
BG56
Liked 295 Times in 111 Posts
Take off the weight from the DragPaks!
Old 03-21-2019, 04:33 PM   #5
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
They all weigh the same.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 03-21-2019, 05:02 PM   #6
George Fitzpatrick
I thought they add 25 to drag pak and removed 25 from copo was that rescinded ?
Old 03-21-2019, 05:19 PM   #7
Ralph A Powell
Liked 225 Times in 136 Posts
NHRA Mudding up the water with no actual testing to see the real world results!
Old 03-21-2019, 05:26 PM   #8
Nick Heath
Liked 566 Times in 135 Posts
They did for the old combinations - but the 2019 CJ and COPO weigh 3575 - same as the 2015 Drag Pak.
http://nhraracer.com/content/general...434&zoneid=132
Old 03-22-2019, 10:27 AM   #9
rognelson777
Liked 135 Times in 74 Posts
Personally I believe, best way to check combinations is heads up racing. Doing it now will allow future changes if one combination should dominate.
Doing it quickly will keep interest in class.
Also, changing pulley size is probably least expensive thing to change.
Will they have to do a lot of testing, sure, but what top teams are not doing a lot of testing.
Class has basically become Prostock version 2.0 18 wheelers hauling stockers around.
rognelson777 is offline   Reply With Quote
Old 03-22-2019, 11:49 AM   #10
Ralph A Powell
The big Question becomes who's Sandbaging when and where?
