Old 03-24-2019, 09:52 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
Default Re: Rockers for stock Eliminator 5.0 SBF
Harland Sharp S40076A vs Scorpion 3221 - does anyone have any feedback? Also, Scorpion Endurance is 28g lighter than their Race rocker so I wanted to see if they are 28g lighter than the Harland also?
Originally Posted by Jeff Blanchard View Post
Lane Automotive has Comp 1052-16 in stock $442.99. Wonder why they would quit making them?
I cracked 4 of these near the roller and only have one spare. Don't see them made anymore. Were they defective?
Bruce Bachelder told me NO, pedestal mount must remain pedestal mount. rule book says the same.
Another black and white ruling that clearly doesn't stand. I have seen everyone shave the pedestals down and put screw-in studs in. I know of a few that have set records and went through tear-down with them.
'65 Mustang SS/L & L/SA
Old 03-24-2019, 12:33 PM   #2
jmantle
Liked 172 Times in 81 Posts
When roller rockers were first approved I asked NHRA if I could switch the stock pedestal rockers out for stud mounts and was told a resounding "NO", read the rule book. I'd always been nervous about the little 5/16 bolts holding down the pedestal but have never had a problem with them. Been running the same set of Sealed Power rockers for 12 seasons along with adjustable pushrods with lots of spring pressure, no issues.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 03-26-2019, 10:41 AM   #3
fordteacherguy
Liked 160 Times in 51 Posts
Haven't ever had a problem with breaking a 5/16 pedestal hold down...haven't heard of any failures at all with pedestals, they can take a lot. I've used the adjustable Ford rockers (B-351) and the PRW's. I had 1 failure with 1 Ford Motorsport rocker...not enough material around the the adjusting threads.....punched a adjuster through....the PRW's have lots more material in the same area and are stronger..but had to play with geometry a bit and cut the stands to get the geometry right. They work fine......
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 03-28-2019, 08:09 AM   #4
Bobby Fazio
I decided to go with PRW, never heard of them and it looks like they are made overseas but the price is right, looks like they have more meat near the roller so hopefully they don't crack like the Comps did. Just hoping they last until my next refresh when I can legally go to the stud rockers.
Old 03-29-2019, 03:57 PM   #5
Coleydog
Liked 53 Times in 38 Posts
On the HP increase, and not sure how the ford rockers look, but on a small block Mopar, Comp claimed 20-30 HP increase using their roller tip steel shaft rockers over the stock stamped ones.?
Mike
Old 03-31-2019, 12:19 PM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Have an LT1 with SA Stock Rockers on 7/16 stud.
They do not need push rod guides.
Is there any performance advantage going to a Roller Tip or full Roller Rocker?
I have a set of 1.6 GM SA Roller Rockers.
Can the Cam be ground and use the 1.6 GM RR’s if it meets Lift Requirements?
Old 03-31-2019, 12:51 PM   #7
james schaechter
Liked 1,443 Times in 302 Posts
Unless your combo came with 1.6 they are not legal. Whenever someone asks for a performance gain report on one part, the answer would be no. The entire combo needs to be considered. Especially cam and springs lifters pushrods etc. when you are talking legal stocker parts, it all has to work together.
James Schaechter 3163 STK
