Old 04-11-2019, 03:21 PM   #1
FED 387
Liked 335 Times in 182 Posts
Default Re: RV broke down
My understanding is "all" diesel fuels are subject to this algae problem mostly because its BIO fuel and WATER---not absolutely sure but the cost for the bio clean additive is not that much if it will help prevent problems---its not a snake oil product it actually works how much how often is based on your vehicle usage but the stuff I use in my truck is about $11-15.00 +/- for a quart bottle depending on the brand and the retailer---never have had any problems ever so its pretty cheap insurance if it solves the problems don't you think? FED 387
Old 04-12-2019, 07:03 AM   #2
Robbie Welch
Liked 262 Times in 124 Posts
Guys thanks for the responds. I'm for sure going to start running and additive to stop the algae. The keep the tank full when setting advise is good and the always listen to the wife is the best thanks. Now I have to deal with the house water pump died. Oh the life of a traveling sportsman race. You've got to love it
Old 04-12-2019, 10:25 AM   #3
FED 387
The algae is caused by several sources mainly condensation in the tank diesel only stays good maybe 6 months not like over a year for the old type fuels--next because those engines are injected when the warm /hot fuel is bypassed back to the tank and it hits the cooler fuel or surfaces in the tank condensation occurs ---over time this allows the algae to develop and build up---google it and read up on it you will get a real good education about what is going on in your system--- the other thing is if your RV is an "older" unit this preventative maintenance most likely has not been done by the previous owners/s so its just a matter of time before this is the result you are going to get---2-3 treatments over a period of time should help the situation--- don't go crazy and go putting lots of additive in the tank cuz if you could look into the tank the bottom of the tank probably has a layer of black tar looking "crud" or a gel like substance that is the result of the algae process---look at the fuel going into the engine it should look clear and light colored not dark which is an indication of "contaminated" fuel---FED 387
