Liked 99 Times in 49 Posts
Thanks
Liked 14 Times in 8 Posts
NAPA used to offer bulk packs with an additional
10-15% off on their popular #'s. FYI Bob |
Liked 182 Times in 61 Posts
Wix also has a racing filter.Little better filteration.I used the 51069R on my camaro.No problems. Wix or wix racing. both better than most others.
That is what NAPA oil filters are, WIX. NAPA parts stores are everywhere. Unless you just like to order things.
Ed Wright 4156 SS/JA |
Ed, the wix racing filter does filter more dirt by means of a glass-enhanced media.Also the can structure is stronger. Yes I know napa filters are made by wix to napa specs. Good filter.But I don't mind spending a couple bucks more to help protect a 15k motor.
Liked 805 Times in 341 Posts
Wix filters for me.
Liked 10 Times in 6 Posts
I switched from Wix Racing filters that have a 60 micron rating,to Moroso,that are rated at 27.I like a bit better filtration.Just my thinking,probably worried over nothing.
Liked 320 Times in 102 Posts
There are no free rides....
If you want more filtration you end up with less flow (pressure)... If flow cannot keep up with the internal engine leakage the motor will seize up no matter what your oil pressure is......unless the pressure is monitored at the last location of oil flow.... A tight clearance engine needs less oil flow than a loose clearance engine... If you monitor oil pressure in the area of the filter it is the highest in the system.... We should be concerned about the lowest oil pressure within the system.... Just something to think about and most of all never forget "The law of unintended consequences" PS: I almost forgot the MOST important thing to remember about oil filters is to get the metallic debris out before it gets to the oil pump and filter.. We have been doing this stuff for so long that we take a lot of the things we do for granted.. Go out and buy a bunch of 1/2" square magnets and position them inside the engine so that the oil draining back to the pan has to flow over and around the magnets. You can place them in the heads, the valley or even in the pan.... The pan part also works for transmissions, both stick & automatic.. Put a couple in see how much metallic debris sticks to the magnets....
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 04-21-2019 at 01:36 PM. Reason: sp |
#9 | |
Napa and Wix filters are the same filters, different packaging. I even got to make my own. The filters made to some other one's specs are for the OE. Bob |
