Old 04-20-2019, 10:43 AM   #11
RKelliher
Liked 182 Times in 61 Posts
Default Re: oil filters
That is what NAPA oil filters are, WIX. NAPA parts stores are everywhere. Unless you just like to order things.
Ed, the wix racing filter does filter more dirt by means of a glass-enhanced media.Also the can structure is stronger. Yes I know napa filters are made by wix to napa specs. Good filter.But I don't mind spending a couple bucks more to help protect a 15k motor.
RKelliher is offline   Reply With Quote
Old 04-20-2019, 11:06 AM   #12
340Cuda
Liked 805 Times in 341 Posts
Wix filters for me.
Old 04-20-2019, 12:12 PM   #13
Dana Fitzpatrick
Liked 10 Times in 6 Posts
I switched from Wix Racing filters that have a 60 micron rating,to Moroso,that are rated at 27.I like a bit better filtration.Just my thinking,probably worried over nothing.
Dana Fitzpatrick is offline   Reply With Quote
Old 04-20-2019, 03:44 PM   #14
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
There are no free rides....
If you want more filtration you end up with less flow (pressure)...
If flow cannot keep up with the internal engine leakage the motor will seize up no matter what your oil pressure is......unless the pressure is monitored at the last location of oil flow....
A tight clearance engine needs less oil flow than a loose clearance engine...
If you monitor oil pressure in the area of the filter it is the highest in the system....
We should be concerned about the lowest oil pressure within the system....
Just something to think about and most of all never forget "The law of unintended consequences"
PS:
I almost forgot the MOST important thing to remember about oil filters is to get the metallic debris out before it gets to the oil pump and filter..
We have been doing this stuff for so long that we take a lot of the things we do for granted..
Go out and buy a bunch of 1/2" square magnets and position them inside the engine so that the oil draining back to the pan has to flow over and around the magnets.
You can place them in the heads, the valley or even in the pan....
The pan part also works for transmissions, both stick & automatic..
Put a couple in see how much metallic debris sticks to the magnets....
Bob Mulry 7516 STK
A & M Motorsports
Old 04-20-2019, 04:13 PM   #15
Roberte
Liked 14 Times in 8 Posts
I've been to the wix factory and can assure you,
Napa and Wix filters are the same filters, different
packaging. I even got to make my own. The filters
made to some other one's specs are for the OE.
Bob
Roberte is offline   Reply With Quote
Old 04-20-2019, 05:20 PM   #16
Greg Barsamian
Liked 427 Times in 97 Posts
Valvoline Packages NAPA Motor Oil as well
Old 04-20-2019, 05:27 PM   #17
CMcAllister
Liked 920 Times in 259 Posts
Micron and flow ratings matter.
https://rehermorrison.com/tech-talk-...is-everything/
Old 04-20-2019, 05:43 PM   #18
Chevy55
Banned
Liked 179 Times in 89 Posts
Just something to think about and most of all never forget "The law of unintended consensuses"
When the oil pressure drops change the filter.
Chevy55 is offline   Reply With Quote
Old 04-20-2019, 11:55 PM   #19
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
I use K&N filters because of contingency and Steve Williams.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 04-21-2019, 10:48 AM   #20
Dana Fitzpatrick
I was concerned about flow. Before I made the switch,I consulted with my engine builder and Moroso.I change the oil and filter every 35 runs and cut the filter open.After one year,no issues.
