Old 05-12-2019, 10:30 AM   #1
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: Brakes help
For what it's worth I changed the pedal ratio and wound up never installing the proportioning valve that I bought. If anything the pedal is a little soft, but I can get over 1000 PSI easily in one shot and it holds fine on the line (as long as the 2-step in on...).
It took a could of tries to find the right bore size for the master cylinder but it was worth taking the time to work it out. I wound up with 1 1/8 inch.
Dave Muller is offline   Reply With Quote
