Liked 53 Times in 38 Posts
I always use one very light spring on the advance. Engine starts at a small degree then flings out after 500 rpm to full advance. Easy to start any high compression engine. Also use a locking collar to allow no shaft up and down movement. I use a stock dist except when needing a tach drive.
Mike |
Liked 759 Times in 379 Posts
This^^^ I would never recommend a locked out distributor when using a stock or stock type distributor. I’ve been running my distributors with 18-20 degrees mechanical advance and all in by 2000 rpm for 25 years. The reward is no hard starting, no kickbacks, no broken flexplate teeth and no broken starter drives. Spins over like the plugs are out.
#3 | |
Liked 5,129 Times in 1,956 Posts
Liked 8,043 Times in 1,527 Posts
This is a perfect example why 1319.5 E.D. Needs to hang out in the .90 neighborhoods....
Like the name... I call him YB E.D.
#6 | |
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-19-2019 at 10:59 AM. |
