Old 07-25-2019, 09:20 AM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Default Re: Anti-Roll bar in Stock
Billy is correct .
Although some have argued that the anti-roll bar is not a traction device , NHRA correctly sees it as such.
Old 07-25-2019, 09:34 AM   #2
Billy Nees
Liked 7,742 Times in 1,740 Posts
Just another interesting (and ignored) Rule Book note,under Traction Bars, sentence4, "device must be installed under leaf spring" which would mean that cal-tracs would not be legal as a portion of the "device" is installed above the leaf spring. Go figure.
Billy Nees 1188 STK, SS
Old 07-25-2019, 11:48 AM   #3
CMcAllister
Liked 920 Times in 259 Posts
I prefer for it to be bolt in/removable in some fashion since it is a wear item that is subject to occasional cleaning/lube/maintenance. Easier to get the assembly out of the car to work on it.
Old 07-25-2019, 12:59 PM   #4
HawkBrosMav
Liked 302 Times in 73 Posts
I'm going to guess this slides by because it mounts in the original hole the leaf spring mounted in so it's not technically mounting "above" even though the Cal-tracs does lower the mounting hole of the spring itself once installed so it is physically above once installed.
