Old 07-31-2019, 08:08 PM   #1
Lyn Smith
Liked 979 Times in 197 Posts
Default Electric Water Pump damage
What is causing this damage to the inside of my electric water pump, and what can I do to stop it. I run just water in the system,and drain it in the fall.
Old 07-31-2019, 08:48 PM   #2
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Electric Water Pump damage
I always understood when you let air get to wet metal it still corroded. I always leave the water in. How about electrolysis?
Old 07-31-2019, 09:33 PM   #3
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Lyn run the Lucas (* it works) cooling system additive or the redline water wetter. Both are good for aluminum blocks/heads/intakes/water pumps. It won’t allow it to corrode
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 08-01-2019, 09:28 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
Lyn,
Wix, #24056 cooling system treatment is also a good product and available at most auto parts stores. It is around $7.00 per quart.
Larry Woodfin 471W
Old 08-01-2019, 11:45 AM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
What fluid do you run in the coolant system? Tap water could have some metals that will attack aluminum. Excess acidity can corrode it to. Check the Ph level of the water you use with a test kit. I run distilled water only and drained the block and pulled the water pump to change the cam this week. Lots of rust in the water but no damage to the WP.
Dale Shearon
68 Mustang 6394
Old 08-01-2019, 12:03 PM   #6
Eman
Liked 133 Times in 76 Posts
The debate will continue about what water to use. I do know that some coolant additives state not to use distilled water. I stick to filtered drinking water for my car.
Old 08-01-2019, 03:08 PM   #7
John Dinkel
Liked 263 Times in 68 Posts
I use Red LINE.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 08-01-2019, 05:06 PM   #8
mschafer
Liked 13 Times in 9 Posts
I use distilled water and add Zerex Super Protector[ZXC04] bought at Napa was in car for 2 years and drained it this winter to change intake, intake water ports looked like new and not sign of electrolysis also run a anode in radiator petcock fitting
mschafer is offline   Reply With Quote
Old 08-01-2019, 06:47 PM   #9
Dissident
Liked 73 Times in 36 Posts
Mr. Smith and others,
IF the surface we are looking at in the pic is aluminum (ie: non-ferrous), the problem is specifically from natural electrical action to corrode the material. IF that is the case, the original surface should have been anodized so as to decrease the action but would be better to use a sacrificial anode in the cooling system as well. IF originally anodized, any scratch through the finish accelerates the problem. IF the surface is supposed to be ferrous, it is surprising that it shows no ferrous oxide (rust) residue. So, it appears to be non-ferrous.
Either way, there are no negatives to use a sacrificial anode in the cooling system. Those type anodes are available at any hardware store or at Lowes, Home Depot, etc.
Regards to All that like this kind of stuff,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 08-01-2019, 09:38 PM   #10
Lyn Smith
Thanks for the info everyone. Someone please post a picture of a anode.I know if I go into the H ware store and ask the lady for a anode, I will get that funny look.LOL
