Liked 20 Times in 15 Posts
Switched over from factory fuel tank to trunk mounted cell. No way can I get a 13,14 or 15" tire/wheel back in the trunk. Can I just mount a rim in the factory spare tire location?
Liked 129 Times in 59 Posts
Is there a requirement to carry a spare tire? I've never seen anything in the rulebook, although if you're looking to add some "legal" weight to your car that may be one way.
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 2,487 Times in 698 Posts
Easier for us to just bolt some weight in or install a weight box.
Liked 320 Times in 102 Posts
I used to use an 8.20 x 15 recapped 8 ply snow tire (sometimes full of water)...
Back in the day there was no such thing as ballast. Either bolt the weight in, in the location that you want or use a weight box. Bob
Liked 231 Times in 107 Posts
I would think that you could run the wheel. I use to run some heavy mufflers hanging under car. They were not hooked up but needed the weight.
Liked 101 Times in 34 Posts
Have you tried one of the “space saver” oem type spare tire/wheel combinations?
I thought about that but am not sure if its legal considering its not available for the combo. Pulled a 13" rim w/o a tire and it cleared. Have the battery and fuel relay mounted where the the weight box would go.
Liked 254 Times in 78 Posts
I would think it would be considered removeable ballast and be legal in that respect. No different than a barbell weight.
Mike Moller NHRA 203 Q-R-T/SA |
Liked 10,769 Times in 2,238 Posts
I was asked by NHRA one time if the spare tire I was carrying would bolt up to the car.
Liked 311 Times in 175 Posts
