Here is my opinion (and you know what they say about opinions), on a bye run a LBTA should be treated no different than a red light. The only difference is that on a bye run red light, you won't see it on the tree if the tree is set properly. Having the bye run means that you have "won" or automatically advanced into the next round, UNLESS you cross the center line or outer boundaries or crash. Again, that's just my opinion.
Advancement or DQ would be fine as long as that rule is known by everyone before hand. If you are ever in that situation and want to make a full run or hit the tree and are not sure of the rule, just put 1 or 2 seconds more in the delay box and go for it. |
Liked 100 Times in 51 Posts
This is from the 2019 NHRA Rulebook.
SINGLE RUNS In situations where a driver is making a single run, he or she is considered the winner once he or she stages and receives the start signal or is declared the winner by the official starter. If a competitor crosses the boundary line on a single run, the elapsed time is voided for lane-choice determination Dan
Dan Foley SC 4698 |
Liked 1,307 Times in 399 Posts
I spoke to a few racers this weekend who told me that once the person stages and as long as no one is in the other lane then they can break the beam even if the tree never activated. It’s called the John force rule as I guess this happened to him previously. Obviously, it’s still a very very gray area with some tracks and racers. I know it happened this weekend at Atco in TAFC. A driver got a bye after his opponent broke on the burnout, he took the tree and hit the 330 cone, even his team thought they got DQed and were bummed till they were told because nobody was I. The other lane they were clear and onto the next round.
Liked 557 Times in 217 Posts
I wanted to add....
Earlier it was said that if you LBTA you were in violation of going down track when the starter did not clear you to. That would get you DQ'ed possibly.. Well once you are given the signal to do a burnout and stage the only way the starter is going to stop you from continuing is to hit the flashing reds on the tree and then walk out to motion you to hold or back up..... You're not in violation of anything if you were cleared to burnout and stage.....and not signaled in some way to NOT attempt to take the tree....
#5 | |
Liked 708 Times in 285 Posts
Tire smoke gets a warning generally....once. Unless you lost control of your car.
The dial ins are assumed correct if you stage, you as the racer accepted what's on your board. Starter is usually back a little ways from starting line and almost always hits the flashing reds rather than just try to get drivers attention. The reds will alert them there is a problem. All this is up to the Starter so if you are doing that job, its your call....along with possibly the race or division director....
#7 | |
Liked 431 Times in 224 Posts
S/ST 51 S/C 53 |
#8 | |
Dan BTW, It was nice talking with you in Topeka.
Dan Foley SC 4698 |
Nice meeting you too, Dan!
S/ST 51 S/C 53 |
