Old 08-15-2019, 04:49 PM   #12
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default Re: 12V racing battery recommendations
I have used two 11.5 lbs Braille battery's for years in the six pack car with zero let downs. Once the starter acted a little slow, battery was ok just a loose cable. My alternator works. I have tested and could go three rounds without charging in between rounds. I did cool car with sprayer until temp was reached then turn off fan. I change them out every three years.
Sounds like you and I have exactly the same battery experience, Larry. This is the 4th season on my two 11.5 lb Braille batteries. I even completely killed them once last year by leaving the water pump on for 5 hours...discovered this fact when they called us up for first round. Charged them for 15 minutes or so, the car started, and I still beat a few people to the lanes.
Paul Merolla is offline   Reply With Quote
