Old 08-22-2019, 05:05 PM   #1
65signet
Liked 49 Times in 22 Posts
Default Re: Electric water pump sb mopar
I use the Moroso belt drive system on factory style pump, works great.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 08-22-2019, 06:28 PM   #2
GTX JOHN
We have been going back to stock pump with belt drive on most
of our cars. It draws much less juice than separate fan and pump
(especially the fan)!
John Irving
741 Stock
741 Super Stock
Old 08-23-2019, 07:37 AM   #3
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I have had zero problems with my Mezeire on my 340. I have friends that had problems with the CSR and Moroso pumps. The Moroso motor and factory water pump on the AMX also works fine, but I was told the Mezeire is lighter . The electric fan is the highest amp draw of anything on the AMX, especially when it starts.
Patric Fox is offline   Reply With Quote
Old 08-23-2019, 09:07 AM   #4
GTOMayhem
Liked 22 Times in 14 Posts
So you are using a belt drive and still using an electric fan?
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 08-23-2019, 07:30 PM   #5
GTX JOHN
Rick Thomason
GTOMayhem
Sorry I was not very clear. With the belt drive = I have fan in stock location
and can use stock shroud and it draws only a moderate amount of juice.
With aftermarket pump I have to use an electric fan mounted on the radiator.
That fan (no matter the brand for me) draws enough juice that I only run it with engine running (I run real working alternators) OR connected to a battery charger while back in the pits.
Hope this helps.....I am old
John Irving
741 Stock
741 Super Stock
