Old 09-03-2019, 09:58 PM   #11
e vassar
Liked 272 Times in 108 Posts
Default Re: Shutting off engine crossing finish line
Mr. E,....if you have not experienced engine problems before, why would you want to shut your engine off now ? Many , many 3 speed trans builders Do NOT recommend this ....
Well I don't know. Maybe I've been lucky. I try to ask questions and learn as much as I can. Maybe with 3 qts of oil in the engine it makes sense to get it shut off ASAP. But otherwise no.
Thanks for the good info.
Old 09-03-2019, 10:02 PM   #12
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Rehr-Morrison has a great article in their tech area why you should shut down the engine at the finish line. A valve body with a clean safe neutral should be used however. There are many tech articles on their site but that are a “must read” if you are a racer.
Old 09-03-2019, 10:37 PM   #13
Dana Fitzpatrick
Liked 10 Times in 6 Posts
On my stick BBC I push the clutch pedal in and let it idle.Should I also key it off?
Dana Fitzpatrick is offline   Reply With Quote
Old 09-03-2019, 10:51 PM   #14
MR DERBY CITY
Liked 8,114 Times in 1,531 Posts
Let me clarify my answer, I am only talking about SBC Stockers with 3 speed GM automatic transmissions with Cheetah shifters...no clean neutral....
Old 09-03-2019, 11:09 PM   #15
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I have a TCI shifter hooked to a reverse valve body c-6.
It also will not make a clean shot from 3rd to neutral
Old 09-03-2019, 11:13 PM   #16
ALMACK
ALMACK's Avatar
Just curious...
Auto trans
Go thru the traps at 120 plus
Straight to neutral and Shut the engine off and coast
I have always wondered how the output shaft gets lubrication since the front pump is not running ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 09-04-2019, 12:08 AM   #17
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
I put my stick car in neutral and shut the engine off, which also shuts off the Racepak.
Shadylane is offline   Reply With Quote
Old 09-04-2019, 06:24 AM   #18
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Lightbulb Re: Shutting off engine crossing finish line
I watched the videos here on class racer. Many of the older cars do this and the newer cars seem to leave it in gear. As mentioned some 3 speed trans builders don't recommend it. The clean neutral valve body would be a must, I would think.
The more people I meet the more I like my dog
Kevin
Old 09-04-2019, 08:06 AM   #19
BRINK
Liked 140 Times in 43 Posts
Don't try it without a clean neutral transmission. Period.
BRINK is offline   Reply With Quote
Old 09-04-2019, 08:45 AM   #20
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Isn't there a danger of the front drum letting go if you free wheel it at that kind of RPM?
Floyd Staggs 787 SST
