Old 09-04-2019, 11:13 PM   #1
mtwilly
Liked 4 Times in 1 Post
Default 4th Gen Rearend
Greetings! This is my first post, so here goes nothin'! I am building a 1995 Firebird to Stock Eliminator specs. I have noticed when looking at cars that others have built, the rear wheels are nice and deep (shallow offset). To my understanding, the rearend has to be stock width, correct? How are they fitting those wheels in there with a stock width rearend? Thanks, everyone. There will be many more questions to come as I undertake this project
mtwilly is offline   Reply With Quote
Old 09-05-2019, 06:46 AM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Default Re: 4th Gen Rearend
I have a complete 12 bolt rear done if you need one.
Glenn Briglio is online now   Reply With Quote
Old 09-05-2019, 04:17 PM   #3
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Take's a little measuring to get the correct offset wheel.
Dave Noll, EF/S ,?/SA 6526
Old 09-05-2019, 05:17 PM   #4
Billy Nees
Liked 7,762 Times in 1,741 Posts
A few year old quote from a DTD, "my boss told me that he had better not see me climbing under cars and measuring rearends anymore". That would lead me to believe that as long as the springs are in the right place and the inner wheel housings aren't modified then you're OK to NOT have a "stock width" rear. Honestly, I don't have a problem with this. If anyone out there would know any different, then I would sure like to know. There IS a new Sheriff in town!
Billy Nees 1188 STK, SS
Old 09-05-2019, 10:32 PM   #5
mtwilly
Here are some pics of what I am seeing. I'm not really interested in 'breaking the rules' so I am trying to figure out how everyone else is doing it. Glenn, I will definitely keep yours in mind. Right now my cash is going towards a trailer that I will pick up in a week or two.
ID:	51637   Click image for larger version
ID:	51638   Click image for larger version
Old 09-06-2019, 09:44 AM   #6
KRatcliff
Liked 534 Times in 143 Posts
Since one of those pics is my car I guess I will answer with what I know at the moment. The rear end is a 12 bolt with the stock width and coil spring mounting locations. It has the stock springs and I don't know offhand what the rear wheel offset is, but they are 10" width Weld Alumistars. I don't have any trouble with clearance.
KRatcliff is offline   Reply With Quote
Old 09-06-2019, 06:19 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I had a 4th gen Firebird and it had a KTRE 12 bolt and from what I knew it was stock width. All stock type mounting brackets for suspension and shocks. Pete Z traction bars and lower bars...
I replaced the springs and put stock ones in there to raise it a little.
10" rims and no clearance problems with any 9" tire....
I don't recall the offset but it was nothing unusual....
Hooked in a car wash....LOL
Rich Biebel
S/C 1479
Stock 147R
Old 09-07-2019, 12:04 AM   #8
mtwilly
Thank you all for the input. I appreciate it. I will see what I can find out for offset on 10" wheels.
Old 09-07-2019, 09:34 AM   #9
jimmyparker
Liked 309 Times in 88 Posts
The rear ends under these cars are not stock width, a stock width rear end would be too wide. Most of the f body cars I've built had a 60" or so axle flange to axle flange rear end. As mentioned earlier if you have the wheels and tires that will be used on the car you can get a more accurate measurement.
jimmyparker is offline   Reply With Quote
Old 09-07-2019, 10:09 AM   #10
Race Clean
Liked 129 Times in 53 Posts
That would lead me to believe that as long as the springs are in the right place and the inner wheel housings aren't modified then you're OK to NOT have a "stock width" rear.!
This must be the norm!
Race Clean is offline   Reply With Quote
