Liked 237 Times in 126 Posts
I've heard that the carb base should be level. Most manifolds are cut to slope down (I think 4 degrees).
Here's an interesting article from On All Cylinders regarding Jerry Bickel. It's not a Stocker, though. https://www.onallcylinders.com/2016/...s-drag-racing/
Banned
Liked 179 Times in 89 Posts
There's two things to consider, one is the driveline angle and the other is that the engine is at least one degree up from level in the front so you don't get air trapped in the engine when filling with coolant.
https://www.iedls.com/uploads/files/...in%20Setup.pdf |
#3 | |
Liked 251 Times in 125 Posts
Liked 920 Times in 259 Posts
If this is a typical big tire backhalf car with the rear u-joint CL higher in the car than the front joint CL, having the engine nose down will help achieve desired operating angles on the joints while keeping the pinion angle negative or nose down - which is desired in a drag car.
Otherwise, using the OE engine 3 degree down in the rear mounting, you get into the "broken back" arraignment. Plus, the oil pan, headers, steering, etc all have to fit each other. It takes some planing and time mocking things up. |
Liked 7 Times in 5 Posts
No big tires for me , its a stock eliminator small block Camaro, and I finally got it to 3 degrees. what does the broken back mean? Thanks for all the replies
#7 | |
Liked 88 Times in 43 Posts
Ideally, you should be able to draw a straight line from the front of the crankshaft, through the transmission, and straight on through BOTH pinion bearings. That way, when you adjust the driveline/pinion angle at the axle housing, the included angle above the pinion is equal to the included angle BELOW the transmission. That way, just like the referenced guide, the "uncancelled angle" is zero. Last edited by Tom Broome; 09-14-2019 at 09:17 AM. |
