Old 09-14-2019, 08:11 AM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default 440 6 pack
Putting together a stocker bottom end and I have 3 blocks to choose from.
The best block checks out with a minimum of .171 cylinder wall thickness. Before machine work is done.
My pistons are .060 over.
The question I have is, would you fill the block or sleeve all eight cylinders?
I've had someone tell me do not fill the blocks you will lose ring seal.
littlemanjoe is offline   Reply With Quote
Old 09-14-2019, 12:43 PM   #2
Bruce Fulper
Liked 54 Times in 33 Posts
Default Re: 440 6 pack
The reason to fill blocks is to preserve ring seal. Increases rigidity. Fill as high as possible leaving 1-1/2" at the top.
Bruce Fulper is offline   Reply With Quote
Old 09-14-2019, 01:25 PM   #3
Jerry Terry
Jerry Terry's Avatar
Liked 450 Times in 133 Posts
We always ran filled blocks never had any problems with ring seal but i never had a mopar if that makes any difference.
Jerry
Retired 3490 3492 STK SS SST
Old 09-15-2019, 12:44 PM   #4
GTX JOHN
Liked 2,486 Times in 697 Posts
Is .171 on thrust side of cylinder.
That is the most significant spot.
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 09-16-2019, 08:21 AM   #5
littlemanjoe
Yes on the thrust side towards the bottom.
Old 09-16-2019, 12:45 PM   #6
GTX JOHN
I would rather see it on the bottom than the top
for the thinner side.
My big blocks are thicker than that by .030/.040.
I think you would be fine with a filled block at that dimension.
Sometimes my filled blocks leaked better after they had been
reringed once....But they were still decent the first time.
John Irving
741 Stock
741 Super Stock
Old 09-18-2019, 10:55 PM   #7
littlemanjoe
Does anyone know if it is legal to put 4 bolt main cap in?
The type I'm looking at bolt through the side of the block.
Old 09-19-2019, 02:16 PM   #8
GTX JOHN
Nope!
Really not needed in a Mopar 440 at this
power level in my opinion.
John Irving
741 Stock
741 Super Stock
