Old 09-19-2019, 11:25 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Radial slick pressure
With a prepped track for S/SS races have run 26 lbs NP.
In fact 30 lbs by mistake at same race. Hooked fine.
Bracket racing that are less maintained.
Use 22-23 lbs in a 4200lb ImpalaSS
Old 09-19-2019, 12:04 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Radial slick pressure
Rim width also has an in influence on pressure. The wider the rim, the more pressure you can run...which is better because it will extend the life of the sidewalls. I have the Hoosier lightweights on 10" rims at 21 lbs on my 3,540+ lb 360 Dart, footbraking and SS springs. Especially with new tire, you can usually see if the tire is making full contact all the way across.
But even if it hooks with more pressure, and theoretically goes a bit faster, you want to keep as much rubber contacting the ground as possible for a little extra "insurance" (consistency).
You should pick up a little ET and RT with radials over bias play.
You may need a touch more pressure once you get the car to leave harder (lower 60').
LOCOMOTION Racing
Old 09-19-2019, 02:15 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
what rear shocks do you have?
Old 09-19-2019, 09:21 PM   #4
dragracer502
dragracer502's Avatar
Liked 10 Times in 8 Posts
If I told you what I ran in mine at Indy this year, you wouldn't believe me.
181
J/SA
F Body
34 lbs
F Federico
NHRA J/SA
dragracer502 is offline   Reply With Quote
