Old 10-07-2019, 03:43 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Funny TPS readings ...
My data logger on my fast system shows my TPS is not at 100% during some of my bad runs. The O 2 reading will show very very lean when this happens. Can I get a new stock TPS from parts store and put on?
Kdw1403 is offline   Reply With Quote
Old 10-07-2019, 06:22 PM   #2
Bobby Fazio
Bobby Fazio's Avatar
Default Re: Funny TPS readings ...
If it is GM I am pretty sure you can pick that up at the parts house. What system are you running? Pull it off the throttle body and see if the plastic is all chewed up. If it is loose and vibrating going downtrack you will get erratic readings and that will be detrimental to the performance, especially in Alpha N mode.
'65 Mustang SS/L & L/SA
Old 10-07-2019, 06:27 PM   #3
Kdw1403
Fast xfi2.0. I’ll take it off and check. Thanks
Old 10-08-2019, 11:51 AM   #4
Liked 10,681 Times in 2,222 Posts
Fast web site lists those parts
Old 10-08-2019, 01:18 PM   #5
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
I would recommend using an OEM TPS sensor. What is the application? Have you learned the tps sensor?
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 10-08-2019, 09:28 PM   #6
Kdw1403
I just bought a TPS. Do I just install it or as you say do I have to calibrate it or learn it? Your car was flying in St. Louis.
