Old 10-09-2019, 11:18 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default 95 lt1 block?
Is it legal to run a regular old style Chevy block rather than a LT1 block in a 98 Camaro in stock eliminator ?
Kdw1403 is offline   Reply With Quote
Old 10-10-2019, 02:58 AM   #2
Greenlight
Liked 81 Times in 23 Posts
Default Re: 95 lt1 block?
Yes, as long as the main bearing size is the same. In other words, you can't run the small main journal Chevy pre-1968 block.
The blocks are NOT a direct replacement. The LT block has a completely different cooling routing system, unique front drive distributor, different timing cover, etc.
Others have converted an LT engine to a earlier generation block, but it's not that easy.
Greenlight is offline   Reply With Quote
Old 10-10-2019, 09:39 AM   #3
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Maybe in Superstock, but in stock you must use the Opti-spark, which requires the LT1 block.
Old 10-10-2019, 10:05 AM   #4
Whalen3186
Liked 109 Times in 32 Posts
MSD and stock GM Opti-spark's will work the traditional style sbc blocks.
Drew Whalen Stk 3186
Whalen3186 is offline   Reply With Quote
Old 10-10-2019, 11:09 AM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Inquiring minds want to know how to do this ? What would you use as a waterpump ?
Old 10-10-2019, 11:41 AM   #6
Whalen3186
Standard sbc water pump with spacers to clear distributor. Water flow can be either direction, these motors don't see enough temperature to need the reverse cooling.
