Liked 184 Times in 113 Posts
Looking at a new set new of gears.
Considering having them Rem and MicroBlue treatment There is Cryo'ing gears for more strength. Does that work with axles? What is the over all benefit..? If you get all this treatment was considering using less gear ratio. D |
Liked 805 Times in 245 Posts
These are things to do only when you have exhausted every other idea of ways to go fast. Total waste of money on an application like you are considering. I would bet whatever amount of money you care to wager that you would see absolutely no difference in ET.
Liked 780 Times in 194 Posts
Contact Tom Watt at Tom's Differentials
http://tomsdifferentials.com/
Liked 71 Times in 38 Posts
I just finished installing a set of 9” REM polished Gleason gears.I don’t think the REM polish will help with performance as much as wear reduction.I also micro blued all the bearings.It certainly helped the rotating torque, but again I doubt I’ll see any performance advantage.The micro blue stuff will most likely help in reducing wear and oil temps depending on the parts that are coated.I wouldn’t change gear ratio because of the polish or coatings.
Liked 799 Times in 236 Posts
Not sure I follow you?
"That'll never work....." |
Liked 280 Times in 139 Posts
There is a member on this board can't recall his name,believe he ran a black 64? BB Mopar. He used to coat/treat RP gears,the cost was very reasonable with good results in terms of gear life and performance gains.He may have sold the company a few years back...gsa612
Liked 7,941 Times in 1,520 Posts
Jim Bailey is his name, Top fuel was his game.....He did sell the business years ago and moved to FLORIDA .
Liked 10 Times in 6 Posts
I know a racer in colorado that would drain the gear oil out of his rear end when he was trying to set national record. stick car.
Tom Moock 5704 STK |
Liked 88 Times in 28 Posts
I installed cryo gears in a 4200 lb wagon, 5:38, after 120 passes they still looked new, 1 qt, synthetic lube.
#10 | |
He rebuilt my 12 Bolt differential decades ago. Tom Watt passed away https://www.hotrod.com/articles/lege...t-passes-away/ |
