Old 10-15-2019, 10:25 PM   #1
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Default Electric water pump drive problem
I have had a Moroso electric water pump drive on my SBF stocker for a couple of years, no problems. This last weekend in Phoenix I burned up two 10 amp drive motors. Obviously they exceeded the max amperage.
I had a 15 amp fuse in line but it didn’t blow, not sure why. I’m using 12 gauge wire.
I figured there may be too much drag on the electric motor so I removed the fan and water pump. I have a 16 inch plastic flex fan installed on the water pump also. I called Moroso and they informed me that their drive kit is not designed to use a fan. Oops.
The water pump seemed to have a lot of resistance when turning the hub. I took the pump to a parts store and compared it to a new one out of the box, they felt the same but I didn’t have anyway to measure them other by feel.
I reinstalled the w\p and fan with my spare drive motor and measured the amperage draw when running, I bypassed the fuse to test.
First with the fan, no coolant. 16.8 amps. Removed the fan, 6.5 amps just driving the w/p. I would have never guessed it. Then added coolant into the system, still without the fan, 8.5 amps. Total draw with fan, pump and coolant is 18.8 amps. Way over the 10 amp capability of the motor.
Not sure if the w/p drag is the problem or not.
May have to find a higher amperage drive motor or add an electric fan.
Anyone have similar experiences?
Kelly
Shadylane is offline   Reply With Quote
Old 10-15-2019, 11:00 PM   #2
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Default Re: Electric water pump drive problem
I had the exact same set up with a metal flex fan for 10 plus years on my bracket car and never had a problem. I, like you discovered recently that having it drive the fan is a no-no.
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 10-16-2019, 12:04 AM   #3
Rory McNeil
Liked 1,103 Times in 301 Posts
Kelly, do you have a new or used water pump? On my own 302 Ford, I found a new water pump had quite a bit of drag, so I installed a used pump, which spun much easier. As for a fan, considering the electric water pump drive doe not spin all that fast anyhow, I doubt a mechanical fan on the water pump would spin fast enough to very effective, so I went with an electric fan instead. Also, its not good to have the toothed belt very tight, as it can lead to premature wear of the electric motor. By the way, the electric motor used by most drive kits, is a Ford heater fan motor, same as most 70s Ford cars and trucks.
NHRA 6390 STK
M/S 85 Mustang
Old 10-16-2019, 03:18 AM   #4
GTX JOHN
Liked 2,471 Times in 696 Posts
We have never had any issue.....We have a Alum. fan on several of our
cars. be sure belt is not very tight. Our Mopar pumps turn very easy or
we replace them. we run 14 tooth pulley instead of standard 10 tooth.
John Irving
741 Stock
741 Super Stock
Old 10-16-2019, 06:29 AM   #5
Ralph A Powell
Liked 225 Times in 136 Posts
Most of the Drag you feel on the new pumps without fulid is the seal creating the Drag.
Old 10-16-2019, 08:52 AM   #6
Shadylane
Shadylane's Avatar
Yep, I understand that most modern water pumps use mechanical seals. The pump was new when installed.
I always keep the belt loose.
Old 10-16-2019, 09:08 AM   #7
Mark Ugrich
Liked 71 Times in 38 Posts
I’ve used an electric water pump drive with a small aluminum flex fan for years. Never had a problem. I believe Moroso offers a different drive pulley that will change the pump speed.
Old 10-16-2019, 10:29 AM   #8
Jeff Stout
Liked 704 Times in 281 Posts
Kelly I have a new Moroso motor in a box I would sell cheap. I live north Phoenix and work central Phoenix.
Old 10-16-2019, 01:59 PM   #9
curtis reed
Liked 125 Times in 59 Posts
You can get a motor that has 4 posts with 2 of them being the same center to center as the Moroso 2 post motor but is a more powerful permanent magnet motor from W. L. Walker 918-583-3109 or wlwalker.com
The part number is 18051. This is the company I work for. We sell stuff to test measure or sample oil but I used this motor on a few friend's water pump and they run much faster also. Depending on the input voltage they will run 2100-2250 rpm. It has the same 5/16" shaft. Just grind down the 2 posts that you don't need. Just an option to consider. Looks like they are about $11 more than the Moroso motor.
Curtis
curtis reed is offline   Reply With Quote
Old 10-16-2019, 04:46 PM   #10
65signet
Liked 44 Times in 21 Posts
I use a plastic fan from summit, super lite and pull some air through radiator. with my moroso water pump kit
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
