Liked 2,486 Times in 697 Posts
We have never had any issue.....We have a Alum. fan on several of our
cars. be sure belt is not very tight. Our Mopar pumps turn very easy or we replace them. we run 14 tooth pulley instead of standard 10 tooth.
Liked 225 Times in 136 Posts
Most of the Drag you feel on the new pumps without fulid is the seal creating the Drag.
Liked 171 Times in 51 Posts
Liked 71 Times in 38 Posts
I’ve used an electric water pump drive with a small aluminum flex fan for years. Never had a problem. I believe Moroso offers a different drive pulley that will change the pump speed.
Liked 704 Times in 281 Posts
Kelly I have a new Moroso motor in a box I would sell cheap. I live north Phoenix and work central Phoenix.
Liked 125 Times in 59 Posts
You can get a motor that has 4 posts with 2 of them being the same center to center as the Moroso 2 post motor but is a more powerful permanent magnet motor from W. L. Walker 918-583-3109 or wlwalker.com
The part number is 18051. This is the company I work for. We sell stuff to test measure or sample oil but I used this motor on a few friend's water pump and they run much faster also. Depending on the input voltage they will run 2100-2250 rpm. It has the same 5/16" shaft. Just grind down the 2 posts that you don't need. Just an option to consider. Looks like they are about $11 more than the Moroso motor. ![]() Curtis |
Liked 49 Times in 22 Posts
I use a plastic fan from summit, super lite and pull some air through radiator. with my moroso water pump kit
Steven Barnes Stock 704 N/SA |
