Old 10-17-2019, 12:54 PM   #14
Default Re: 4th Gen F Body V6
Originally Posted by Darrel Goheen View Post
I am still considering swapping my LT1 for the 3800 (3.8L) engine in my 95 Camaro. I cannot find anywhere whether the LT1 and RWD 3800 has the same trans mounting configuration. Also will the 3800 work with the K member that I have? Thanks.
No . It has the FWD pattern. You'd need a not too common FWD pattern 200 case, used in early 2.8 or 2.5 applications..Good luck finding one.
I believe the cradle will work with the long V6 engine mounts.
The 185 hp version looks better to me on paper, if you're not in a hurry..No pistons approved.
