Old 11-01-2019, 07:21 PM   #1
Tom Broome
Liked 88 Times in 43 Posts
Default Re: Hemi piston pop-up
Originally Posted by Race Clean View Post
As I understand the rule as it once where "if it sticks out of the hole you can't compensate for the gasket" as you can if it's down in the hole.
I could be wrong, it may have changed, or they dont care.
I agree on all points.
I haven't had to worry about dome height for quite a while. But as I recall it was "above deck"......nothing said about gaskets.
Apparently no one that currently races one of these combinations wants to give any "tips".
Tom Broome is offline   Reply With Quote
Old 11-01-2019, 08:32 PM   #2
HankN
We has the rule book and Pat C don’t answer.
That’s why I ask here at CR.
My Swedish good ’byddy’ cost me allot before.
I asked Don Little over mail on aluminium heads but no reply back for 4 month.
Maybe he is more into super S theese days.
HankN is offline   Reply With Quote
Old 11-02-2019, 02:47 AM   #3
Rory McNeil
Liked 1,104 Times in 302 Posts
I can not offer any input to your Hemi engine question, but since you say this car was a 440-6 barrel car from Div. 6, do you have Wes Libbys old Dodge Challenger ? I have not seen Wes or the Challenger in at least 10 years, so the timeline fits.
NHRA 6390 STK
M/S 85 Mustang
Old 11-02-2019, 09:11 AM   #4
HankN
Lets see if someone know who read this.
This is the car.
https://www.dragracing.eu/driver.asp?id=313
Old 11-05-2019, 08:18 AM   #5
HankN
A update.
So far nothing from NHRA tech about this.
Tested several tech directors but voice message and I send message and mail, but so far nothing back.
But I did get from tech director Pat C a answer, but it was no answer on the gasket issue on AB motors but he said still the bigger cam tunnels is not Ok in stock and has not been, will not be.
If one read the rule book he seem's correct.
-On the gasket issue I can't see a rule.
I guess one has so to do what one will do here.
Old 11-06-2019, 01:26 PM   #6
HankN
Now I got in contact with west central div and I was all Ok with the thicker gasket.
So now that is cleared out, but..
From Pat C I got a mail today, and if that is correct understood he said he asked every full time NHRA tech official, and all have said it’s not legal.
If that was meant on bigger cam tunnels or thicker gaskets it’s not said, or maybe he mean both.
It's all very confusing.
Why is this not cleared out in the rulebook.
One wonder if roller lifters is coming to stock now 2020.
RPM from heads flow, free seats, free valevesprings, roller rockers, fat cams, more oil in pan, aftermarket parts and new rods/piston that handle it.
Dan Dvorak was years ago into put stock in specs of comp/cam and let rest be free ( not titanium ) and use a OEM intake but aftermarket heads to get it more easy.
Old 11-07-2019, 02:17 PM   #7
James L Miller
Liked 25 Times in 16 Posts
"GASKETS Any replacement or aftermarket gasket permitted. If thinner-than stock head gaskets are used, thickness loss must be made up with additional deck clearance. Difference in deck clearance can also be made up using thicker-than-stock head gaskets."
I would interpret this to include a negative deck clearance for the Hemi.
Mopar 2 Ya!
